101 - 108 of 108 Posts
No. The solenoid is capped. The line that went to solenoid is now going to delete kit. My delete kit came pre tapped so no worries there (Steeda)
Doing mine later today with the Steeda delete kit. Cant wait to get rid of the constant BOV sound on the highway. Also installing a Steeda cold air inlet intake. Btw on Sale right now for $140. No way I would ever spend more than that.
Hi everyone,
Wanted to put together a proper "How to" for moving the blow off valve over to natural vacuum and removing it from the stock solenoid. Hopefully this helps anyone that is looking to make their Turbosmart or Boomba BOV blow off properly! This might requiring adjusting your BOV after the install to adjust it to your desired BOV preference.
Shout out to a fellow ST member for letting me use his car to complete this write up!
Parts required:
1 - 3/16" Vacuum cap (NAPA Auto is where I picked up a 5 pack for $3)
1 - 2 feet of fuel line 3/16" ID
1 - clamp
1 - Sound symposer delete kit with vacuum port or CPE
( cp-e™ Ford EcoBoost 1.6L & 2.0L Turbo MAPtap™ - cp-e™
cp-e™ BlockD™ Ford Focus ST Sound Symposer Delete - cp-e™
COBB Support )
Tool:
pair of pliers and cutters
8mm wrench to remove the sound symposer delete
maybe a 7/16" wrench to put on the barb
(Picture shows a barb we has that we picked up from ACE hardware because he didn't have the barb that came with his COBB SSD, for reference if you need one it is a 1/8NPT with a 3/16" barb part number is in the picture 4504130)
Next picture is just reference to show what it should all look like stock:
1) Unplug vacuum line going to the BOV from the solenoid
2) Using a vac cap, cap off the solenoid port that the line was removed from
3) Remove factory soft vacuum line from the hard line and replace it with the 2 feet of soft line and route to MAPTAP or sound delete vacuum source
4) last one is just to show the location of the sound delete and how the line routes to it's location.
Thanks
Nick
thanks for the write up. just got it done, and it makes a huge difference!!
2018 Ford Focus ST (ST2)
Possible dumb question: Is it worth doing this if you're only running an intake and factory BOV?
Bueller.. Bueller??
Anyone?
Sent from my S21 Ultra 5G using Tapatalk
When I first hooked mine up like this, I was still running the Mountune BPV, which is basically a better-built version of the stock BPV; I didn't really notice much of a difference since it's still relatively quiet, but it certainly vented less. Shortly thereafter, I switched to the Boomba Adjustable, and finally to the Turbosmart 50/50.
I've considered both the Boomba and Turbosmart 50/50. The Boomba seems too hissy sounding. What did you think of each? @EVH
For me, it's the Turbosmart 50/50--I should have just bought it to begin with.
