Driver door controls not working
22K views 67 replies 16 participants last post by  johnpfacer
#1 ·
So I installed the rear Strut bar from massive today. Well when I went for a test drive I found the driver door controls for the windows and mirrors no longer work. So I pulled the bar off and checked the harness from the rear fuse box to the rear passenger door. Nothing damaged or unhooked minus the hatch area light. I swapped fuses for the driver door module with the passenger side since all the other door controls still work. Still nothing. Even pulled the controls and door module and reseated the connectors. Nada. I'm getting pretty frustrated with this since it worked before I started the install and can't find any damage. The only other thing I did was jump start the car since my battery got a bit low having the doors open during the Strut bar install.
Sent from another garage.
#3 ·
All the power for the door modules comes from the RBJB (rear battery junction box)
You need to get a meter and start looking there. What year is your ST?
#7 ·
The Massive rear strut bar uses a aluminum spacer the requires you to move the main harness out of its way to install. I would suggest that you check that area for damage to the wiring.
390253
390254
390255
390256
390257
390258
#8 ·
#9 ·
Not that it would be the same, but just in case: I've reflashed the tune (COBB AP) several times and twice I had an issue where the auto-up/down function stopped on 1 or more of the windows... Turning the car off and back on fixed it once. The 2nd time I had ultimately uninstalled and reinstalled the tune, then cycled power again before it would work.
I'm only adding this for an option that doesn't involve the physical connections (since it seems that was covered pretty well already!). Something like a self-calibration check that got a checksum error or something equally pita with the electronics failed to fully enable. If you're hitting buttons for the windows & nothing happens or changes in the next start up then it might be worth getting a new battery (which you should do anyways :) ).
I hope it works out!
#10 ·
Flashing back to stock didn't work. Also the battery I have is a light weight battery. So it does drain kinda quick. With having the doors open for an extended period of time without unhooking the battery was enough to drop the charge so the car wouldn't start.
#12 ·
Have you gone through the fuses? I did a rear strut bar install and forgot to disconnect the battery. With the jumble of wires it would be pretty easy to short to ground on the chassis or a random bolt so I ended up disconnecting it 1/2 way through the install.
Since SSgtjrobertson was kind enough to post up all of the wiring/electronics, it makes it easy to check if something tapped out/blew. Looks like F1 - F7 in the RJB would be a good place to start.
If nothing there, I could only start looking for voltage along the lines. Unfortunately I couldn't tell you what voltage the window motors use... Probably 12V if I'm a good guesser :p
#13 ·
Yeah already tested the fuses. The door control fuses are in the hatch. All of them have power on both sides. As for the wires I did unwrap the bundle where the bar installs and can't find any signs of broken or damage wires. No squished wire jackets or nicks.
#15 ·
My next step is to borrow the driver side switches from a friend's st. They pop out super easy.
That's a good option then. Pretty fishy issue, now that you've confirmed the only things that I can think of to check... Sorry I can't be of more help!
You should borrow your buddies battery while you're at it. That's one of those things that will eat at me until it's either tried or the issue gets fixed and proves that wasn't it, lol.
#30 ·
You didn't disturb a ground or something did you? Take one off and move it?
#35 ·
I'm a bit baffled, but to undo that I'd have to ohm out ever single wire in that harness if there isn't anything else... Which is either what the tech will have to do, or just replace it (if it's more easy & cost effective).
So your source when using the key fob works, thus the window & doorlock modules work as intended. However, the button presses from the car door panel are not being recognized; Even though You've verified that the door panel controls all function correctly....
So the something in-between the physical buttons and the door/window is what needs to be tracked down... This is where the schematics SsgtJRobinson are super useful, but like Duece said: if only you were closer so I could help you knock stuff off the checklist.
The dealership will spend way too long with you car, and you will spend way too much money... I hope you can avoid that, if possible.
#39 ·
Have you tried flashing the bcm back to factory with Forscan to disable the global windows to see if it made a difference? I had something similar happen to me and my ESC would not turn off with the switch, flashed the ipc back to default settings and it started working. Somehow something in there got corrupted and caused an issue.
#53 ·
What happened to Mr "I CHECKED ALL THE FUSES!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
This is a great outcome. Congrats!!
