So after @boarder140's constant hounding I decided to throw this build thread together. I'm going to keep an overview here, then throw pics in on other posts and the like.
Mods right now
Performance engine mods
ATP GTX3076r Gen 2
Tial IWG Actuator, 16 psi spring.
Speed Perf6rmanc3 Port Injection Kit
CP-e Intake, race red, oiled.
Velossa Tech BIGGER MOUTH SNORKEL!!! Now gen 3 equipped
2.3 Ecoboost Mustang Throttle Body
Depo BEAST 5.5" FMIC
CP-E Red Hotside charge pipe
CP-e Exhale kit in Race Red with HKS SSQV limited Gunmetal BOV.
CJPP Catless DP The unicorn of exhaust parts. (Original batch)
RDC rear DP mount
Agency Power Twin Tip exhaust, which I love.
AP3, with overpriced carbon fiber front plate, lol
Full 93 Freektuned.
MSD Coil packs
NGK one step colder plugs gapped at .026
TTR PSMM and DSMM in Red of course.
CP-E Stage 2 RMM
Massive Speed Balance Shaft Delete
Massive Speed Oil Pan Baffle
Transmission
Spec stage 3+ Clutch
Spec Aluminum Flywheel
MFactory LSD.
Synchrotech carbon lined synchros
JPC SS clutch line
Fresh trans internals
Fresh updated shift tower
Brakes
Wilwood FNSL6 kit in Red of course!! 7416 pad
Wilwood two piece 14" rotors, just slotted
Velossa Tech Stage one Brake cooling ducts in red.
TCE rear SS brake lines
DBA RS rear rotors
New rear Calipers
Damond rear brake bushings
Mazda 3 Brackets, aka Frankenbrake
Hawk HPS Pads just in the rear, Wilwood BP-20 streets up front
G2 Caliper paint in Red
Suspension
Koni yellows 2013 flavor
Swift springs 2013 flavor
TB Strut bar
TB Gusseted Traction bar
TB Rear Traction bar
TB Mid brace
TB adustable RSB endlinks
JBR Rear sway bar
JBR billet RSB mounts
Shifter stuffs
Boomba Short shifter
Boomba shifter base bushings
Boomba Trans bushings
JBR shift arm, cream of the crop right now
Aluminum shifter cable ends.
ANARCHY MOTIVE Collared shift knob, rough red with ST outline
Dipped and modified reverse lockout.
Redline 1.8" shorter quad stitch white and red shift boot and arm rest cover. awesome stuff!!
Custom welded shift cable bracket.
Lighting mods
TLF stage three headlights in 35w with 4500k lamps
LED upgrades to trunk and puddle lights, VLED Flank bulbs in 6k.
35w D3S ballast conversion and Philips X-treme Vision lamps on my ST3 headlights, currently not equipped
VLED Micro Evolution fogs in 6k
Fusion fog light retrofit, Which is ****ing awesome!!!
Ebay LED tails, Clear/black/red and dipped.
VLED'S badass LED reverse lamps
VLED led Cornering lamps. Took a bit of trimming here and there on the connector, but they are bright. Which are in my non equipped OEM headlights
Wheels/tires
The dipped snowflakes with 245/40/R18 Bridgestone Potenza RE980as, great tires btw.
Dipped Wheels- https://www.focusst.org/forum/focus-st-builds/38950-dirty-duecette.html#post856916
Winter set of blizzaks 225 width is a mistake, lol, on MSW 17" rims, no TPMS which is super annoying
Other mods
Mustang GT styled Hood Vents, real custom, lol
Damond OCC stage 1 mount 1
Breedt SSD with port
3d printed windshield washer cap
Cobb Exhaust hangers
RDC DP bracket, a must have for use with CJPP DPs
Vibrant "J" defouler, set to largest orfice
Rally Armor mud flaps
Bosch icon wipers 28Aoe 28 BOE and valeo rear replacement.
Weathertech mats, full set.
Velossa Tech Wing Lift Kit in RED!!!
Velossa Tech Center caps, high temp premium
Velossa Tech Dead Pedal
Velossa Tech custom "Stache" rear emblem, a glorious red mustache
Velossa Tech rear Diffuser 6-pack.
Sanded all honey comb
Dipped front end some
Custom crash bar insert
Red/carbon fiber emblem overlays
AA amp swap
94r Battery swap, Northstar battery
Breedt Thin Pedal spacer
Redline ELITE hood struts, stainless FTW!!!
Escort Redline Radar Detector, hardwired on Escort Stickycup Mount.
Put sound deadening in trunk and under rear seats.
Square Jellyfish Air vent phone mount, Running Waze on my Galaxy S7
Sanded, and penetroxed grounds in engine bay, plus installed the two extra cables.
FLUIDS
Pennzoil ULTRA Platinum Oil
Fram ULTRA Guard filter, the larger one,
Motul DCTF
Wilwood EXP brake fluid
Previous Parts
Gram Lights 57xtreme 18x8.5 +33 offset in semigloss black
^Wrapped with 255/35-R18 Michelin Pilot Super Sports
Injen 3"(lies) titanium tip exhaust(it's 2.5" at the dp)
Cobb shifter Plate, 1st gen
Breedt shifter Arm
Wilwood BNSL6 calipers
EBC Volvo front rotors, slotted
Wilwood BP-10 front pads
Hawk HPS + rear pads
VLED VX3 gen 2 fogs in 6k
NTC shifter bushing, 1st gen
Depo racing hotside pipe
Depo racing coldside pipe
Rocket Science Snorkle. Last one made iirc.
Velossa Tech 1st gen Snorkle
Velossa Tech 2nd gen snorkle
Velossa Tech 1st gen brake ducts
Boomba BOV
TB front traction bar
35w ballast upgrade D3S swap in my ST3 projectors
Fully adjusted wastegate on the K03
Rocket Science thermal wrapped airbox
WC Lathewerks knob, 4 ring burnt titanium
Green filter
Cobb Intake
Fake HKS SSQV, which broke
Spec 2+ clutch which broke apart internally, faulty sprung hub. Spec wasnt helpful, blamed worn trans alignment pins on my 30k mile car virgin trans removal, or a misaligned trans input shaft, lmfao.
Things happening soon, which means I have purchased and am awaiting a prime time to install.
Cabin Air Filter
SS Tuning Fender Flare kit
Mountune Radiator and all hoses
Finish my 2.3 build, then install that beast
Damond OCC location 2, so I'd be running dual OCC.
Things on the drawing board
Aquamist and 2.5 gal reservoir, maybe x2
Wider blizzaks, like 245 or wider.
New rims
Wider MPSS, 275 or 285
Re-building/altering my TLF stage three POS headlights, in a proper, custom, Wrenchworx fashion.
Mods right now
ATP GTX3076r Gen 2
RDC rear DP mount
Full 93 Freektuned.
MSD Coil packs
CP-E Stage 2 RMM
Transmission
MFactory LSD.
JPC SS clutch line
Brakes
DBA RS rear rotors
New rear Calipers
Suspension
TB Strut bar
TB Mid brace
JBR Rear sway bar
Shifter stuffs
Lighting mods
Wheels/tires
Other mods
AA amp swap
FLUIDS
Motul DCTF
Previous Parts
Breedt shifter Arm
Boomba BOV
Green filter
Cobb Intake
Cabin Air Filter
New rims
