561 - 580 of 621 Posts
Pulled my plugs today at 43,500 miles, replaced with ITV22's. They all look the same and look fine, however I noticed these little built-up circles under the ground electrode. Anyone know what this is/means? I think they show up in the one pic.
Just pulled my #2 plug which is my cylinder that has the most knock. ITV22 on for 7k miles. Any thoughts? <img src="http://www.focusst.org/forum/attachment.php?attachmentid=93900"/><img src="http://www.focusst.org/forum/attachment.php?attachmentid=93901"/>
Yup looks normal
Thought I would share this so maybe it will help someone out. I pulled my denso's out to check and re gap them yesterday. All four plugs looked good but 2 of them has a black oily substance on the base of the plug and base of the threads, but the rest of the plug 3/4 of threads leading down to the electrode and electrode was dry and clean.
I was like wtf??? Gap the plugs and re install. Thought about it today and after discussing it with Hemicouple I figured it out....
If you spill oil when pouring it in the funnel and it runs all down the outside of the fill tube during an oil change .... Pretty sure the base of your 2 plugs closest to the fill tube will ... well you get the picture :smile:
Build date: 2014.5
Odo: 14645
Mods: fr tune, steeda fmic
Plugs: itv-24's
Plugs are 1-4 L-R
Plug two worries me a bit.
Can anyone offer some insight as to why #2 would have less of a "sooty" look around the edges and maybe some more peppering on the porcelain?
Datalogging via dash command and no issues detected and she runs like a top.
The plugs look fine to me. Can't see the electrode in the provided pic. How was the gap when you checked them?
Sorry I don't know why left that out, .028. The electrodes looked all the same and can really only be seen on plug 4 (barely). I didn't get a pic of the electrodes head on, doh!
I reset the KAM and went for a nice drive, things ran smoothly. Monitoring I didn't see any problems either. Compression is good through all 4.
I agree, those plugs look fine, how many miles on them and what was the original gap set to @ install?
Im very confused. I read the first few pages im not reading all of them. Would be nice if 1st post was updated with all info. Anyway im stage 3 stock turbo no intention of changing, cpe everything with fswerks cobb ap and frpp exhaust. Do I NEED to upgrade my plugs, or its not necessary? If i should what plugs do I use and what do I gap them to?
P.s. 2013 st with a oct 2012 build i believe if i remember correctly. 13k currently
Went ahead and gapped my NGK LTR7IX-11 spark plugs that I purchased earlier this week to 0.026". The metal gapping tool left some "etching" in the ground strap electrode from the metal-on-metal contact, is this something I should worry about?
Should I purchase new plugs and just go the route of gapping them by tapping them on a hard surface?
