Some info...
Motorcraft® Orange Antifreeze/Coolant Concentrated VC-3-B (US p/n); CVC-3-B2 (Canada p/n) WSS-M97B44-D (specification)
Motorcraft® Orange Antifreeze/Coolant Prediluted VC-3DIL-B (US p/n); CVC-3DIL-B (Canada p/n) WSS-M97B44-D2 (specification)
Motorcraft® Premium Cooling System Flush VC-1 (p/n) ESR-M14P7-A (specification)
Capacity in a bone-dry system: 6.81 qt
WARNING: Always allow the engine to cool before opening the cooling system. Do not unscrew the coolant pressure relief cap when the engine is operating or the cooling system is hot. The cooling system is under pressure; steam and hot liquid can come out forcefully when the cap is loosened slightly. Failure to follow these instructions may result in serious personal injury.
NOTICE: The engine cooling system is filled with Motorcraft® Orange Antifreeze/Coolant. Always fill the cooling system with the manufacturer's specified coolant. Chemically flush the cooling system if a non-specified coolant has been used. Refer to Cooling System Flushing in this section. Failure to follow these instructions may damage the engine or cooling system.
NOTE: During normal vehicle operation, Motorcraft® Orange Antifreeze/Coolant may change color from orange to pink or light red. As long as the engine coolant is clear and uncontaminated, this color change does not indicate the engine coolant has degraded nor does it require the engine coolant to be drained, the system to be flushed, or the engine coolant to be replaced.
Recommended coolant concentration is 48/52 to 50/50 (freeze protection -31°C to -37°C [-30°F to -34°F]) engine coolant to distilled water. For concentrations measured 48/52 to 50/50 (freeze protection -31°C to -37°C [-30°F to -34°F]), use Motorcraft® Orange Antifreeze/Coolant Prediluted to maintain a coolant concentration in this same range. Material : Motorcraft® Orange Antifreeze/Coolant Prediluted / VC-3DIL-B (WSS-M97B44-D2)
For extremely cold climates (less than -37°C [-34°F]):
It may be necessary to increase the coolant concentration above 50%.
NEVER increase the coolant concentration above 60%.
Maximum coolant concentration is 60/40 for cold weather areas.
A coolant concentration of 60% provides freeze point protection down to -50°C (-58°F).
Engine coolant concentration above 60% will decrease the overheat protection characteristics of the engine coolant and may damage the engine.
For extremely hot climates:
It is still necessary to maintain the coolant concentration above 40%.
NEVER decrease the coolant concentration below 40%.
Minimum coolant concentration is 40/60 for warm weather areas.
Engine coolant concentration below 40% will decrease the corrosion and freeze protection characteristics of the engine coolant and may damage the engine.
Vehicles driven year-round in non-extreme climates should use a 48/52 to 50/50 (freeze protection -31°C to -37°C [-30°F to -34°F]) mixture of engine coolant and distilled water for optimum cooling system and engine protection.
@hemiCouple@Stratified
