1,761 - 1,780 of 2,075 Posts
That is odd, without seeing a picture of your VIN# and entering it myself I don't see any reason it shouldn't be working.
I could PM my VIN to you if that will make things easier.
I not saying I don't trust you but I'm willing to try it out. I'm curious as to what is happening also.
i'm not saying you do! it's really strange, maybe i'm doing something wrong and don't realize it. i'm sending the pm now
Nevermind! just tried it again before sending the message and it went through. maybe i did fat finger it and no notice each time, or something was up with the site when i was looking.
Sweet, good to hear.
I've been meaning to do this. I have one of the bluetooth adaptors and a laptop with Bluetooth. How much of a pita is it just for the global open and close?
Sent from my SAMSUNG-SM-G900A using Tapatalk
This is what I used with laptop and I have done about 4 different cars now with no problems.
Now I read something about wiring in a switch. Is that needed with the bluetooth?
I didn't need one, I remember reading that somewhere but I don't remember the specifics around it. I think it was if you only had a specific type of adapter if I'm not mistaken. (Don't take my word for it though)
The switch is for switching between MS and HS. When I did this I did not need the switch and you probably won't need it either. The only time I have seen the need for the switch is for forscan.
Edit: I have some links to threads about everything on my computer but am currently upgrading it so I can't pull the links. I will shoot you a pm with them once I finish up.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Reactions: elyk864
So question on the key fob auto up/down. I'm having to hit the unlock/lock button twice and hold to activate, which is annoying on lock due to the horn sounding. Tried both options when setting but it's the same. Car is a MY15 so not sure if something changed. Am I missing something or can I disable the horn on double press lock?
This is a little off topic. (I think?) I recently did the FoCCCus and Forscan stuff, but it has me wondering, is there a tuning solution for PC. I'd much more prefer to tune my car straight from my computer rather then the SCT flasher. I'm thinking like Hondata style tuning, except without the huge price tag.(I refuse to use the access port, its a pride thing. Always had super chips and american vehicles.)
You're really doing yourself disservice by writing off the Accessport so blindly. Speaking as someone who used to own an SCT X4 and currently owns an Accessport, the AP3 is a far superior device in so many ways. I sold my <6 mos. old X4 for a $100 loss after having picked up my AP3. I wrote down some of my thoughts after comparing them here.
Hello to all
I have a Ford Focus SE 2015 and i would like to to the following modifications on it:
1) DRL
Lights stay on all the time, no matter the position of the light switch. Even when i have them off, the low beams will be on.
2) Global Open/close of windows
Can you please advise:
1) Is this possible to do on my car version?
2) which are the parameters i need to modify?
I have downloaded FoCCCus_0.8.6 and purchased this OBD2 interface
http://www.amazon.com/iKKEGOL-Interf.../dp/B00I9XH1NO
thanks so much in advance
For DRL edit option #16 DRL: set to Always Headlights.
I'm not sure what you mean by global open/close of windows, but if you wan't auto locking you can also enable it.
If you don't have Hill start, you can also try to enable it.
Hello to all
1) DRL
Amazon.com: iKKEGOL V1.5 USB Interface ODBII ODB2 Diagnostic Car Auto Scanner Tool Cable Scan: Automotive
