121 - 140 of 322 Posts
Just did this last night at 11,500 miles. Dark brown and nasty as everyone else said, I baby my car so I was pretty surprised. Multiple length 8MM (short and long) allen keys make this so much easier. After about 10 miles on the Motul I could feel shifts start to get smoother.
Amsoil doesn't make a fluid thats WSS-M2C200-D2 spec.
Nope...unfortunately. They do however make a DCT specific fluid, but it's only listed as meeting 936-A spec.
So here's the question...if it's a DCT fluid, what's the difference between the two specs; or rather yet, what would the down side be, if any, of running a DCT fluid that only met 936-A?
Ford made a spec for a reason. Many DCTs are different. Wet clutch, dry clutch and various versions between. Specing DCT fluid for a fully manual transmission was no doubt very well thought out. It's like a manufacturer saying to run GL4 in a manual transmission even though GL5 is a later spec. Typically that has to do with brass syncros.
You can give that fluid a shot and see what happens. If it shifts like **** then drain it and use something else.
don't mean to be a butt hole but i'm in the motherland where they have the castrol and motul for pretty cheap 11 euro. which one would be better? performance or preference?
Discussion starter · #131 ·
That I couldn't tell you. I do know the spec was changed in 2011 on the MT-82 for the Mustang because of people complaining about cold shifting. Spec went from WSD-M2C200-C to WSS-M2C200-D2 on all Ford manuals. The WSD-M2C200-C is a 75W-90 gear oil part # XT-M5-QS
we have been waiting for fluid to leave back order status. got this notification today.
we will have kits to do your change including new drain and fill plugs for about same price you are finding it :)
will add link to website soon :)
Panda delivered on this! I was just about to place my order on ebay and I decided to see if they had it up yet. It does come with new fill and drain plugs as well, but for $38 total. Nice!
https://www.pandamotorworks.com/col....com/collections/focus-st/products/panda-motorworks-approved-transmission-fluid
Just make sure it's in stock. I ordered it and didn't hear anything for a few weeks, so cancelled and went the eBay route.
Very good to know. Thanks for the heads up. @chris@pandamotorworks Is this in stock right now?
EDIT: I reached out to Panda. They have plenty in stock and ready to ship!
I changed the fluid this weekend. Man these guys weren't kidding. Shifting like butter. Changed at 35k miles, don't drive the car hard. The fluid was much more brown than I thought it would be. The hex drain plug twisted like butter while tightening it back down, don't think i'll be able to get it back off easily which is odd. I didn't over tighten, it just stripped. It was also 118*F outside when I did it though.
Yeah I didn't believe I was going to notice much of a difference after this. But you guys were right.
After I installed the boomba SS, there was a bit more force needed to move the shifter into gear. But now it's back to "stock" feel where it pretty much goes in with minimal effort.
My fluid was a coffee brown color as well @ 55k miles.
