461 - 480 of 621 Posts
Do you recommend new plugs for stage 1 tune? If so which ones?
Yes, any tune it is suggested 1 step colder
siht daer nac uoy fi revo em lloR
The set of ITV24's I got 4 days ago came all at 0.032, I closed them out a little to 0.029 before I installed them. I'm running them because that's what Ford advertises to run with the FRPP Calibration The stock plugs I took out with only 6000 miles, were gapped at 0.035
So I pulled a plug and it said CYFS12PC, which was replaced by CYFS12Y2 so I assume they are the same heat range. I called my local dealer and they said for the Focus ST, the plug that was recommended was the Y2 plug. But I looked at the NGK designation on my PC plug and it was ILTR6G8G so which plug do I get to go 1 step colder than what I have?
700 miles until my final spark plug testing video!!!
Thanks a lot for your back to back testing, will be interesting to see how the ITV24's look like after the 10k miles mark, and how they're wearing with respect of the 22's.
My 24s all had a very tight .032 gap. I don't understand why some of you are closing that gap. A smaller gap resists blowout but I'm yet to see blowout problems. If anything a wider gap would be favorable for performance but I trend to stick close to factory as it's usually optimal.
Sent from my SM-N900P using Tapatalk
