221 - 240 of 621 Posts
Where the logs on an Accessport V1.x map or the new V2.0 map? The V2.0 map notes included the following
Fixed a bug that caused the Catalyst Temperature to read inaccurately high
Not ready to lose my tunes from FSW. Probably won't upgrade until I get a crackpipe from Ollie.
Since all the tunes were done around the same time I'm willing to bet that even with v2.0 map the stock plugs are still going to record higher temps.
Has anyone asked yet how going to 1 step colder plugs might be affected by this ridiculous cold weather we have been having?
Not sure if this would even make a difference b/c like it has been previously mentioned, the plug temperature is not really the same thing as combustion temperature.
In case anyone is wondering about this...I did some more research and found this one NGK's website:
As the air temperature or humidity decreases, the air density increases, requiring a richer air-fuel mixture. If the air-fuel mixture is not properly richened, and the mixture is too lean, higher cylinder pressures / temperatures, knocking, and the subsequent increase in the spark plug tip temperatures can result.
As the air temperature or humidity increases, the air density decreases, requiring a leaner air-fuel mixture. If the air-fuel mixture is too rich, decreased performance and/or carbon fouling can result.
Pretty interesting. But it actually has the opposite affect as I was expecting. So in reality using the colder plugs during winter would actually be even more benefit to the engine.
How hard are they to gap? Just got mine ordered last night for edge autosport.
With the right tools, very easy. This tool i used solely to bend the ground electrode. The wire gauges are useless because there are only 6 options. This is the feeler gauge I used to get the right gap. You can swap around the blades to whatever you want down to the thousandth (.001) of an inch.
There is no difference in the logs between the NGK and OEM plugs. Colder plugs prevent pre-ignition and not detonation. The knock sensor only picks up detonation. If the car is running smoothly with no issues the colder plugs are a good purchase and some insurance against pre-ignition.
Cylinder 4 is unhappy in a couple of these logs as it looks to be the noisiest cylinder. There is a relationship between charge temperatures and the correction values. What is probably happening is that as the charge temperatures get into the 70s consistently cyl 4 starts to knock first.
I suggest taking more heatsoaked logs by doing a multi gear pull 2-3-4 taking each gear to redline.
For comparison here are some logs with Cobb stage 2 and the ltr7 plugs ign corr 1-4. Less timing is being pulled but it also has less boost. logs 1 and 3 show timing advancing, log 2 has timing being pulled -1.38, log for shows -.5. I will take your advise and log some 2-3-4 pulls soon. Thanks again for reviewing those logs.
https://www.dropbox.com/s/6sc068f3mbnxy5j/cobb2ltr7-1.csv
https://www.dropbox.com/s/qoiz4m9m90qpo8a/cobb2ltr7-2.csv
https://www.dropbox.com/s/rgcffauv2e4ijg6/cobb2ltr7-3.csv
https://www.dropbox.com/s/3kszldyfhyrgpmr/cobb2ltr7-4.csv
For comparison here are some logs with Cobb stage 2 and the ltr7 plugs. Less timing is being pulled but it also has less boost. logs 1 and 3 show timing advancing, log 2 has timing being pulled -1.38, log for shows -.5 I will take your advise and log some 2-3-4 pulls soon. Thanks again for reviewing those logs.
https://www.dropbox.com/s/vhwaj1sm0x0jnoz/cobb2ltr7-1.csv
https://www.dropbox.com/s/u7jeuy00ycv1ef0/cobb2ltr7-2.csv
https://www.dropbox.com/s/kom36j3kojmphny/cobb2ltr7-3.csv
https://www.dropbox.com/s/rewlc9atki2pr0b/cobb2ltr7-4.csv
Not a problem and yes the COBB map is a bit less aggressive. Putting the motor under higher temperature load usually reveals if a tune is too aggressive.
Haha at least you don't drive a Dodge Dart (besides the obvious reasons...)!!
"The Dart—at least 1.4-liter turbo models—uses NGK iridium spark plugs, which retail for $33 each on Mopar’s parts site, but a massive backorder on these plugs meant that we were charged 25 percent extra to get the plugs in posthaste. This pushed the per-plug price to a staggering $43.56. It gets worse—we couldn’t find the plugs from parts suppliers like NAPA or O’Reilly, and even though the plugs are produced by NGK for Mopar, they don’t appear on NGK’s databases. It seems that for now, Chrysler is the sole source for these plugs, and they’re not cheap. Backyard mechanics, take note."
-Car & Driver
Cyl 4 is like that in my car too. It's always the first to get -1.5,-2.0 correction
my number 4 cyl went as far as -4 correction with the FSW tune not nearly as bad with the Cobb
Randy told me his tune was pulling more timing than needed, IIRC. Even the stock tune pulls timing.
As long as the knock sensors "detect" knock they will pull timing regardless of the tune installed (unless the tune disables them). Any engine will knock at one point or another but you want to stay away from severe or constant knock.
Knock sensors are just microphones tuned to listen for the signature knock sound around the time the spark plugs fire. They are not foolproof but these days they are quite reliable and are used more and more for adaptive strategies such as on this car.
