61 - 80 of 374 Posts
Does anyone know if the AP V3 adds any functionality in terms of faster data logging of more parameters over the V2?
Personally im a bit of a logging whore but i'm lazy too. lol I like to have what I need to tune Boost, Timing and Fuel on one log.
Yes, would be nice to get more at one time. I thought using a laptop would allow more but the error message says the ecu is limited to 64bytes. So it may not be a Cobb issue?
I just counted 14 parameters on the log, and I had to go to a single gauge to do that many.
There is still a limit on the maximum number of parameters but the V3 should have a 33% faster logging rate versus the V2 for the same parameters.
I know you can data log via laptop just like the SCT devices, is there a file that can auto select the more pertinent data points like SCT can?
Sorry if I missed the inference but, with ATR/ATP can you log more PIDs? I am looking at this from a purely data collection standpoint where ALL is better than most, regardless of immediate necessity.
Currently, Accesstuner and the Accessport share the exact same PID lists; aside from Estimated Horsepower which is ATR/ATP only. We are looking to enhance the monitor and datalog tasks in a future update which will only be available on the V3 due to the hardware horsepower it contains compared to the V2. Right now both V2 and V3 are limited to a maximum of 56 bytes of data and they will warn you if the monitor/datalog selections are over that limit. We are looking to double this capacity as well as increase the rate in which those packets are exchanged.
We've got a lot of great things coming on this platform and look forward to hearing your feedback to make these products even better!
Cheers,
-Braden @ COBB
Discussion starter · #72 ·
Cheers,
-Braden @ COBB
This is excellent news. With the number of PIDs that are logged on this platform the higher bandwidth is very welcome. Great work!
Cheers,
-Braden @ COBB
You guys rock. 10 monitors would be dope.
This is my first attempt at posting a data log on here so hopefully it works. I have the FSW stage 1 93 tune. I have a COBB CAI and I always run 93. I am getting a -2 correction on my 1cyl at the high end of 4th and 5th pulls. I have adjusted the log settings to log all four cylinders but have not yet had a chance to get out and take any logs with the new parameters. Is there something I should be worried about with this data or can I just mark it up to the 'winter blend' gas I have here in Baltimore right now? I have posted three logs. They were taken about five to ten min apart from each other. Also, I do not have the tuner program so I am unable to adjust my tunes at all. To be honest, I wouldn't know where to start anyway.
1st run:
https://docs.google.com/spreadsheet/ccc?key=0AguyHhnJZVmadFE5NDVUN1RTMzVNbEdBenZ4R1NBQXc&usp=sharing
2nd run:
https://docs.google.com/spreadsheet/ccc?key=0AguyHhnJZVmadFNZTGpubml0ZktlVjhtM2FObXhZc2c&usp=sharing
3rd run:
https://docs.google.com/spreadsheet/ccc?key=0AguyHhnJZVmadDl2WFJnNG9MVjFCTVRhUkNfMUpNdWc&usp=sharing
1st run:
2nd run:
3rd run:
Please post your full name if you're going to post logs. I have no idea who you are so I can't look at your file. :) Or email me data logs versus having them here. Sales at fswerks dottt commm.
The first run is odd to look at and you aren't keeping the gas to the floor, though that isn't a huge deal since it was pressed far enough for the most part. It's just not ideal to stab it and then right away let off the gas a bit. I see the -2 at the end of 5th gear in the first run. I don't really like it to go to -2 so I'd like to adjust that. What is your Octane Adjust Ratio Learned value on the AP? That is good to log, always.
The second run is much better to look at and looks like you kept your foot to the floor mostly. It would be good to start the run earlier in the RPMs to see more of what is going on, though. Spark looks fine. Again, I'd want to know what the OAR Learned is.
The 3rd run looks incomplete. Was there an issue with that run? The data for the Ign Corr isn't displaying correctly, graphically, but I do see the -2 there at the top end. I'd like to know what the OAR Learned is since the overall Ign Timing is pretty low at that point.
Do you feel like you're using the highest quality gas that you can? You might want to try a different brand and station if you aren't sure.
Discussion starter · #77 · (Edited)
1st run:
2nd run:
3rd run:
Eventually by the 3rd run your intercooler was very much heatsoaked and this resulted in knock which is the negative cylinder correction you are seeing. To make a better assessment having all cylinder corrections logged will give a clearer picture. If they are all pulling timing then the fuel and tune are not getting along.
I think the secondary purpose (or possibly primary, lol) of this and similar threads is to get people used to posting logs on this forum and for tuners and other members with some experience and expertise to chime in publicly in order to educate members to eventually allow them to better understand their own logs and tunes. Keeping these discussion private between tuners or members is contrary to this purpose and does nothing to further the platform or educate its members. You can always PM private details like full names and you can always email logs and questions to a specific tuner; however, it would be very nice to also keep them posted for the public (logs, not private information). No harm and only good will become of the practice, imo.
You are so polite on "this" message board. :)
+1
The more the merrier
Reactions: Alex@Stratified
