Weird Rattling/ Grinding Noise
2K views 4 replies 4 participants last post by  Sttzeee
#1 ·
Hello there I’m hoping that I could get some help on diagnosing something on my 2014 Focus ST2. Recently I’ve noticing a weird grinding/ rattling noise coming from the passenger side of my vehicle whenever I accelerate. It gets progressively louder the higher I bring the rpm’s up and seems to be more intense from 1-3. Can’t hear the noise when I’m in neutral and it goes away when I put in the clutch. My mods consist of, rear motor mounts, awe track exhaust, cold air intake, blow off valve, upgraded intercooler, short shifter, lowering springs, and a Cobb stage 2 tune. Any help. I found a video that sounds exactly like my noise I’ll tag below.
I’ve owned the car for only a few months and it currently has 115k miles
#5 ·
Oki so , had a very similar sound , was thinking I was just having wheel hop during quick acceleration was super concerned… changed rear motor mount to Cobb performance mount ( pretty tight fit on the sts comes with extra vibration s but reduces wheel hop like crazy ) thought my problem was fixed 2 weeks later same **** , realized my other mounts were ****ed too , top mount on passenger side under coolant was completely blown 😂, super easy to replace then … another couple of weeks boom last mount (driver side trans mount) my car making this mf noise again , so thinking bc I upgraded all other mounts to performance caused more wear on my stock mounts/bearings, after i upgraded all to Cobb and AWR mounts can confidently say this sound completely reduced as well a huge reduction in wheel hop …can’t say this is going to be the same fix for you but attempt changing all mounts typically When one is ****ed they all are , you can take the cheaper route see abt changing all your bushings in the bearings 1st but highly recommend going performance if you’re going to change all 3 anyway , you won’t have to change them out again .
