Hey everyone, I've run into a bit of an issue with my shifter after swapping out my engine. It seems like the linkage is messed up, but I tried doing the reset and it didn't do anything.
Here's the issue:
Going up from neutral I have one gear; regardless of I start in first, third, or fifth, the shifter always goes to the third position. Going down from neutral I also have one gear; regardless of whether I start in second, fourth, or sixth, the shifter always goes to the fourth position.
It gets a little ****y because I don't have reverse, but pulling up on the reverse lockout gives me two more gears to shift into.
I've tried every possible way to reset the shifter cables but haven't had any luck. If anyone has ever run into this or has any other ideas please let me know! I can post videos if needed.
Thank you so much!
Here's the issue:
Thank you so much!
