81 - 100 of 154 Posts
I cant help with the trans information you're needing but as far as MPG goes, these engines' mileage suffers drastically when the ambient temps are cold, as well as when engine speed is around 3000rpm and above (which it is at 80). So, next summer wheb its 85 outside and you go on a trip, go the speed limit, youll get drastically better mpg.
Man, you're like 3x as crazy as I am and 100x faster. Talking about swapping transmission internals is blowing my mind and given your success so far I don't doubt you can do it.
Re: LSDs, I have one in my TCST and it's pretty great. I haven't driven an ST without one before so I can't give a good A-B comparison, but it definitely holds traction a lot better than any open diff fwd car I've driven - not a small difference. I got an MFactory unit just because it was available at a good discount at the time and it seems like pretty good quality.
Discussion starter · #83 ·
I'm in the opposite boat--all of my vehicles have been open diff (they've also all been 5-speeds, so looking for reverse up and left has taken a little adjustment). I've never cracked open a transmission like what I'm talking about, and I'd like to think I could figure it out. My biggest fear is trying to open the case and having parts fall out before I see where they're supposed to go. I haven't yet found a good manual on tearing down the transmission like I have for my other vehicles.
Discussion starter · #84 ·
Almost forgot to post this rather minor upgrade...
Switched over from the integrated keyhead remote design to this aftermarket flip key. After a few weeks, I'm not crazy about the unlock button, but it's much easier to pocket carry. If the unlock button just had a ridge or a couple of dimples to make it easier to find, I'd have no complaints.
Reactions: TurboGT
Looks nice - does the trunk button do anything?
Discussion starter · #87 ·
It unlocks the back doors, same as the stock remote except you don't have to hit it twice. I found that a little odd, since I always thought the 2x was from the car's end, not the remote. Might be a different command set or something.
Reactions: Duece McCracken
Discussion starter · #89 ·
@Duff I need to know or see a small write up of switching from the transit Connect seats to Focus seats in the van. Mainly interested in the wire harness and see if there's an issue with removing the seats without the air bag deploymnet.
I haven't swapped seats yet, but it's on my list. Probably not doing Focus seats though--I've got the factory TC leather option, which is a sort of tan and brown combo that doesn't exist on the Focus. I don't have them with me this week, but I have wiring diagram manuals for both Focus and TC, and can check to see if the connectors are the same. More than likely, I'll end up with C-Max or Escape seats--we just added a C-Max to the fleet, so I should be able to compare Focus, TC, and C-Max seats side by side.
Reactions: LostInTransit
Discussion starter · #90 ·
I know I'm a bit overdue for an update. We're at about 25,000 miles on the swap, so far with only one real issue--I lost brake fluid out of the clutch hydraulics. It definitely caught me by surprise--four hours into a 6-hour trip, we were about to make a quick pit stop. I pushed in the clutch pedal coming off the freeway and it went to the floor. Of course, both the gas station and "travel plaza" at the exit were out of brake fluid, so I bribed a tow service to bring me a bottle of fluid. Managed to use the clutch to get on the freeway, and only touched it twice the rest of the drive.
It appeared that there was fluid on top of the transmission, leaking from one of the quick connect fittings on the clutch line. Of course, getting one delivered while I was there was impossible, so the 6-hour drive the other way was made longer by me stopping every 40 miles or so to check and/or top off the reservoir. Got the line replaced, and it sat for a couple of weeks without losing any fluid. Took it to run a few errands, and ended up with a dry reservoir. As it turns out, the slave cylinder is leaking like crazy, but only if the engine is running. I'm getting going pulling the transmission to address that today (with far less than the usual complement of tools than I'd like).
Otherwise, we're getting a ton of use out of it, being more practical than a pickup for most hauling tasks (an 85-inch TV in the box fits inside with the doors closed!), more fun than a minivan probably ever should be, and really showed its capabilities on a 1,500 mile trip towing a trailer a while back. While I'd posted before that I was still kind of underwhelmed by the overall fuel economy, I was pleasantly surprised how it did towing. At 7,200lbs gross combination weight, setting the cruise control just under 70 mph for most of the trip, with a 5x8 enclosed trailer (i.e. a brick slightly taller than the van), we ended up right at 19 mpg overall. I think our worst tank was mid-16s (headwinds in Iowa), and the best was just over 20. Of all the vehicles I've towed with, it might be my favorite--the low center of gravity of the TC, low hitch position, and long wheelbase (with rear axle really far back there) made for a very stable combination. A 4-inch rise on the ball mount got it up into the typically-recommended 18" range, and was still low enough that both doors opened without the ball or coupler interfering. Also, for anyone debating cargo doors vs. liftgate, that definitely wouldn't be possible with the trailer attached.
The biggest knock on the whole towing experience is that I bought the plug-in wiring adapter from Curt (I think). It was relatively easy to install, but was obviously designed by someone who only had access to a cargo van. Had they had a passenger wagon, they would have chosen to source power and ground on the passenger side of the harness, where both are readily available at the rear power distribution block. It's going to be returned, and I now have the factory trailer module that I'll be making a wiring harness for (Ford doesn't seem to be able to find the pieces necessary). My plan there is to order the European market 13-pin connector, and make an adapter to give me more conventional US-style 4- and 7-pin plugs. (The Euro design is much easier to live with, and I'll eventually be towing a custom camper that will be wired to take advantage of the extra circuits.)
Discussion starter · #92 ·
Hey Duff now that the engine is out or is it still out, would be a good time to check to see if a Ford Focus sway bar will fit which is located behind the engine in this approximate location.
That picture was 25k miles ago! But a Focus sway bar should fit just fine--the subframe and end links are the same. Things like struts, strut bearings, and ball joints are also the same, but the knuckles and lower control arms are different.
Discussion starter · #94 ·
That's odd because I locate a site called Mevotech TTX series which has a couple of cross references between the TC and Focus:
2018 Focus Parts List
2020 Transit Connect Parts List
Note that both links list the same lower control arm as being the same for the Focus and TC..
The factory control arms are definitely different, though most replacements appear to be interchangeable. The knuckles are also technically interchangeable, but will screw up Ackerman angles since the wheelbases are different.
Discussion starter · #96 ·
A little bit of an update is long overdue. Going back to the original post in this thread, I had initially intended to use the MTX75, and had a 5-speed shifter assembly installed. When I switched to the MMT6 mid-project, I also had to switch to ST shifter cables, and the 5-speed shifter assembly worked (but without the reverse lockout, making first and second a little hard to find without some practice). A while back, I got a 6-speed shifter assembly, but the cable lengths didn't match up--even lifting the lockout collar, going all the way left (with the side-to-side cable at max adjustment) still landed you in first gear instead of reverse. I put the 5-speed shifter assembly back in, and ordered Transit Connect cables from Lithuania. And waited...
Last week I finally had all the parts in one place to try to set everything up. I hooked the cables to the shifter and transmission, and everything worked just like I expected. Went through the hassle of fishing the cables through the floor, and--uh-oh--the cables were too short. Looking at what I got, and the cables I had in hand, I'd ended up with cables for the 1.5L diesel Transit Connect, which uses the iB6 6-speed. Tried again with a set of cables for the MMT6/1.6L diesel combo, and it still wasn't quite right (but closer).
In the end, I just modified the ST left-right cable, cutting a little bit off of the end of the threaded rod, to get the adjustment I needed:
Now it has the right shifter installed, and shifts like it should:
Yesterday I went ahead and changed oil (but forgot to collect a sample to send to Blackstone...ugh), and put on a new hard plastic engine cover. I knew these existed because of some threads on this forum, but was only finding them upwards of $200 shipped. Since I needed one for each Transit Connect, my partner's C-Max and Focus, I took a gamble on a bulk order from overseas (had to order 10, and didn't really get to see any pictures of what I was getting). Since the old one had been thoroughly soaked in brake fluid from the slave cylinder failing, and has been on there for 187,000 miles, it was time to go. Fit was good, and the panel is solid. The new opening to direct air over the AC compressor should add at least 10 hp, right?
I'm taking comfort in knowing that if I ever have another leak, fluid will either puddle on the engine cover or drip down, making it easier to catch and address before getting stuck on an off-ramp in the middle of nowhere at 2 am with no clutch pedal. The panels I don't need are currently listed in the classifieds.
Next up is new struts (currently leaning toward Bilstien B6s, but open to suggestions).
  • Helpful
Reactions: TurboGT and MtnMan
Discussion starter · #97 ·
Another quick update--I was needing to haul a bunch of stuff again (moving is an odyssey...), and went for a hitch rack instead of a trailer this time. I bought the "ATV" rack from Harbor Freight since it has a few inches of rise and the TC hitch is really low, and it worked out just about perfect for the 6 big containers I loaded on the back.
That trip crossed the 31,000-mile post-swap mark, and I think the containers were a neutral or slight positive impact on fuel mileage. This trip logged just shy of 25 mpg, with most of it cruising at just under 80. Real close to 300 lbs on the hitch rack, and at least 1,000 lbs of stuff behind the second row (ignore the straps--that was temporary just shuffling vehicles in and out of the driveway).
Discussion starter · #98 ·
I suppose no news is good news here--life has been busy, so the little van that could has been doing all kinds of work. Another 1,000 mile trip with a U-haul trailer is in the books, transported a new washer and dryer (with room in the second row still for the furry guy), and picked up 10 (!!!) bundles of attic insulation--doors closed. I managed to forget to take pictures, but if you want this van to be dead quiet at 80 mph, that does the trick. It was stuffed to the point that both back doors and side doors were helping to compress insulation, so there was simply no room for anything to rattle.
I didn't go across the scales this time--a little less weight in the van itself, but definitely more in the trailer. Didn't fight headwinds quite as much, so finished the trip on the high side of 20 mpg.
Duff, I am doing a similar swap right now. Mechanically and electrically I am done. I am down to the Central Configuration changes. I have trued 3 different J2534 adaptors and none have worked. Which adaptor are you using with Forscan? Thanks in advance.
Discussion starter · #100 ·
This one: Amazon.com
