501 - 520 of 621 Posts
Hi Skizzo, did you change them yet ? do you have a veredict ?
^^^Skizzo, I've been following you all along. Looking forward to seeing your longterm results. JP
Awesome, thanks again for the time you've put into this dude, highly appreciated, more than glad I went this spark plugs.
Reactions: skizzo81
Do you have photos of every heat range for analysis?
I have video of the stock versus the 22's and 24's in the first 2 videos. I didn't take video of the used 24's because they looked perfect in color and had ZERO wear. so if you look at the color of the 22's when I pulled them out they are exactly the same color. a nice tan brownish color, not white and not black.
I'm starting to feel like a caveman renewing my interest on working on cars. The spark plugs hide under these rectangles ? Do you need to remove the air intake to get to the last one?
If I'm tappin I'm probably lifting.
Reactions: 13 FOCUS ST2
when i pulled my 22's they were super white.
I saw you removed them. Interesting as that's what I'm putting in. I'll keep the stockers incase this doesn't go well.
I run a mbrp intake and didnt remove them. Came out and went in easy. Took 15 minutes or so
I have the cp-e intake and did not need to remove the intake tube. I was able to access all four spark plugs without issue. More info on my spark plug change here.
The "rectangles" are coil-on-plug. Instead of a single large coil with a mechanical distributor, our cars use a small coil on top of each spark plug which is controlled electronically.
