The following series of post represent over a year and a half of research. I started this project due to the numerous requests for diagrams, connector pinouts, & component troubleshooting. This will be an ongoing process and will remained locked from general comments until complete in order to keep information properly organized.
I'm moving it into the maintenance thread so that members can begin to use the information while it is being updated to include the following information:
Full diagrams for engine harness 2013 - 2014 & 2015 - 2018.
Connector view and Pinouts associated replacement pigtails.
Physical locations of components & troubleshooting procedures where applicable.
Components Glossary:
AAT - (AMBIENT AIR TEMPERATURE) Post #8
(13-14 Diagram 5, Post #2)
(15-18 Diagram 5, Post #5)
A/C PT - (A/C PRESSURE TRANSDUCER) Post #10
APP - (ACCELERATOR PEDAL POSITION) Post #12
(13-14 Diagram 8, Post #3)
(15-18 Diagram 8, Post #6)
BCM - (BODY CONTROL MODULE) Post #14 - #18
Supplemental information
BJB - (BATTERY JUNCTION BOX) Post #20
*HVJB - (HIGH VOLTAGE JUNCTION BOX) Post #21
BPP - (BRAKE PEDAL POSITION) Post #22
(13-14 Diagram 10, Post #3)
(15-18 Diagram 10, Post #6)
C1035C - (PRIMARY ENGINE HARNESS CONNECTOR TO THE BJB)
Post #23
CHT - (CYLINDER HEAD TEMPERATURE) Post #24
(13-14 Diagram 4, Post #2)
(15-18 Diagram 4, Post #5)
CKP - (CRANKSHAFT POSITION)
CMP - (CAMSHAFT POSITION)
CMCPRP - (CLUTCH MASTER CYLINDER PUSH ROD POSITION)
COP - (COIL ON PLUG)
CVM - (CRANKCASE VENTILATION MONITOR)
CPCCD - (CLUTCH PEDAL CRUISE CONTROL DEACTIVATOR)
CPP - (CLUTCH PEDAL POSITION)
ECT - (ENGINE COOLANT TEMPERATURE)
ETC - (ELECTRONIC THROTTLE CONTROL)
EVAP - (EVAPORATIVE EMISSIONS)
*PURGE VALVE & CANISTER VENT
FI - (FUEL INJECTOR)
FIP - (FUEL INJECTION PUMP HP)
FPA - (FUEL PUMP ASSEMBLY LP)
FPCM - (FUEL PUMP CONTROL MODULE)
FRP - (FUEL RAIL PRESSURE)
FPS - (FUEL PRESSURE SENSOR)
FTP - (FUEL TANK PRESSURE)
GROUNDING POINTS
HO2S1 - (HEATED OXYGEN SENSOR WIDEBAND)
HO2S2 - (HEATED OXYGEN SENSOR NARROW BAND)
IAT - (INTAKE AIR TEMPERATURE)
KS - (KNOCK SENSOR)
MAP - (MANIFOLD ABSOLUTE PRESSURE)
NG - (NOISE GENERATOR SOUND SYMPOSER)
OPS - (OIL PRESSURE SWITCH)
PCM - (POWERTRAIN CONTROL MODULE)
TC - (TURBOCHARGER WGA SOLENOID)
TCBP/ CACT - (TURBOCHARGER BOOSTPRESSURE / CHARGE AIRCOOLER TEMPERATURE TMAP)
TCBY - (TURBOCHARGER BYPASS BOV SOLENOID)
VCT - (VARIABLE CAMSHAFT TIMING SOLENOID)
Some additional topics of interest regarding the electrical system.
LIVE, NUDE, SENSORS! (Engine Sensors Explained) Part 1 - 4
It's been a minute since I have had the time to write something up for the community due to my professional and home life. So I wanted to touch on a topic that I get a lot of questions about. Sensors. Not just what they do or where they are located on the vehicle, but how they work. Now I have...
Everything you wanted to know about a Digital Multimeter...
Part 1: Now I could write an entire book about how a DMM (digital multimeter) works but other people have already written enough books that never get read. I want you know know some of the basic fundamentals of a meter to help you understand how to use it for your projects and repairs. Meters...
12 Volt 101 - The series.
This will be the first in a series about automotive electrical. I will attempt to cover as many topics as I can with an emphasis on real world examples with pictures and diagrams whenever possible. Even though it will relate to the ST platform for the most part hopefully it will help to provide...
Very basic electrical troubleshooting
Over the years I have questioned fellow mechanics and enthusiasts about what they believed their weak points were as it relates to automotive repairs or modifications. Surprisingly the answer to my question was overwhelmingly the same each time, electrical. Ask anyone to remove the factory...
DISSECTING FORD'S ECOBOOST ENGINE
While falling down my usual self inflicted "I wonder what's down this rabbit hole?" I happened to stumble Upon this article. It is probably one of the best high level overview of the Ford Ecoboost platform I have been able to find outside of overly technical white papers or engineering talks. If...
Ford / EPC connector resource
While I have been hard at work on Project Reasonable Overkill I keep running across instances of people needing repair connectors or extension harnesses for various projects. ( Throttle body, MAP sensor, O2 sensors, etc.) Some weeks back I posted a factory resource for identification of these...
While I'm and continuing to update this if anyone has any questions or ideas please PM me. I will do my best to answer as soon as I can.
Thanks & Stay Safe!
J
Please note that I have done my absolute best to verify that the information included in this thread is as accurate as possible. Neither I, nor any other staff member here take responsibility for any damage resulting from misuse of the information within.
