Name ONE ST Feature others might not know.....
771K views 1.6K replies 515 participants last post by  MtnMan
#1 ·
The drivers sun visor extends out when you pull on it; if you swing it around to the door side, you can pull it out to get better coverage.
Works at the windshield also, but not a good angle.
The passenger side does not do this!!
Uh-oh, was that 2 factoids......
#4 ·
I was unaware of that as well! My turn... If you accidentally place the passenger windshield wiper above the driver's on the windshield, when you turn on your car they will sweep and go back down in the correct position.
#9 ·
Just to add to that, according to the manual the first position it stops will cause less buffering then fully open.
As for my own fact, if you car is locked and you open the hatch up, once you shut it you do not need to relock your doors. It does it automatically (shown by flashing the lights.) Usually I lock my doors then open the trunk if I need to take something out of it. Saves me having to relock the car with my hands full.
#868 ·
Is that on st1 and st2? I havecst3 and mine doesn't fold flat.
Sent from my GT-N5110 using Tapatalk
#42 ·
Do you know if there is a time limit to this? Like, would that be what you would do at a drive in theatre?
#353 ·
just tried that, must be an st3 feature;)
Reactions: chad1140
#32 ·
The car has cloaking technology
After spirited braking for a certain amount if time the car bathes itself in a cloud o brake dust. Enabling you to downplay the looks of the car and park In ****ty neighborhoods
This is a good thread and hopefully some hidden features get unearthed
I didn't know my xterra had two gloveboxes for about a year
#43 ·
Lmfao that's the damn truth. Good one. My favorite so far.
#37 ·
Laying the seats down, I fit well over 100 boxes of donuts and had room for probably 200 more for a fundraiser I did. So if ever you wanted to rob a Krispy Kreme...
Sent from my iPhone using the App
#39 ·
You're such a thug! So 300 boxes of donuts......you're lucky you didn't get pulled over by the cops just for the 100 boxes.
Easy everyone, I'm a retired former military cop. I used to get these jokes all the time.
Reactions: Shieldze1025
#38 ·
This has been mentioned before in earlier threads.
Holding the reset button too long in an attempt to reset the mileage computer after fill-up results in another screen with a plethora of data screens.
(The reset button is the left side OK button dial pad on the steering wheel and this occurs right after restarting the car)
Once you see that everything is reset let go, or you'll be in the diagnostics mode. Do not attempt this when at night and you're driving the whole dash will go out......YIKES!
#954 ·
This has been mentioned before in earlier threads. Holding the reset button too long in an attempt to reset the mileage computer after fill-up results in another screen with a plethora of data screens. (The reset button is the left side OK button dial pad on the steering wheel and this occurs right after restarting the car) Once you see that everything is reset let go, or you'll be in the diagnostics mode. Do not attempt this when at night and you're driving the whole dash will go out......YIKES!
this happened to me last week! Lol
#869 ·
You know that your door unlocks if you just open the car without touching the sensors right? That's why the manual tells you not to touch any part of the door handle (except for the black sensor), when locking your doors.
