Well the LanEVO AWD is front-baised and is still do a really well job in drag, rally, circuit, ect. [emoji2]
Sent from my LG-D500 using Tapatalk
No. Don't confuse
biased and
based
The evo is a transversely mounted, awd car. This makes it FWD based, unlike the Impreza which is a longitudinal mounted front engine; making it "RWD based awd" (This has nothing to do with power delivery). BIAS has to do with how much of the power split is going F/R (and R/L but for this discussion F/R is all that really matters).
All other things being equal the Evo would be "better" (more balanced) with a RWD based setup, but it makes up for it by having a simply superb AWD system.
We've yet to see the Focus RS in action so it's possible their system won't behave like this, but generally the problem exhibited by these systems in these situations is they're unable to keep all four wheels spinning in very low traction situations, they're constantly looking for the most traction instead of just spinning the drive shafts. In deep snow often times no one wheel has enough traction available to move the car and you basically just want all four wheels spinning, contributing as much traction as they're able to at any given time to sustain forward momentum(this is why jeeps which get into the truly rough stuff employ lockers). Systems that employ a resting split are extremely predictable and controllable in snow, because the computer isn't all of the sudden changing the grip characteristics around on you. I've yet to drive an AWD system with a lot of electronic intervention that felt nearly as good as these all time systems in snow/really slippery stuff.
For my money if I'm in Evo/STi territory I want a proper AWD drivetrain with a center, front and rear diff (until something truly better comes along), I'm also not at all a fan of a brake biased open front differential in this segment (I've never liked these systems, I don't like having to replace brakes prematurely)...this seems very wrong to me, use brakes to assist in traction all you want but a proper LSD should be doing the heavy lifting up front. I don't want my car eating it's brakes to mimic an LSD.
The systems employed by the RS vs the Evo do not seem all that similar to me after looking over what technical information is available.
I also worry this will be a limited production vehicle (two years or so) which could cause parts for it to become expensive years down the road. This however is coming from someone who buys cars with the expectation of keeping them around awhile (I've 0 plans to get rid of my WRX until it becomes an unreliable money pit).
