1,961 - 1,980 of 2,075 Posts
HMMM thanks for the reply. im a mac guy and only have a pc laptop for tuning lol. I will have to play around with it. IM dying to update the bcm.
Has this exact thing happened to you?
Yes, except that I'm using a Bluetooth ELM adapter instead of USB.
Which version of Windows are you running?
Sent from my SAMSUNG-SM-G891A using Tapatalk
OK, so after ignoring this post for a LOOOONNNNGGGGG time, has there been any updates on a WIRED USB in the past 18 or so months?
I am about to just head down to Ford and have some palms greased so I can get onto IDS.
Sooooo someone finally answered this a couple of pages after this: https://www.amazon.com/dp/B005ZWM0R4/ref=cm_sw_r_cp_ep_dp_M2iLzbDWA55KW
Is there an as-built editor for the Fiesta? Or will this work for it as well? Have a bunch of guys in a local group that want to know if global windows are possible for them
Everyone has said the FiST is Global windowless :( they never made it possible. I have searched and searched and find nothing but "nope can't be done"
Man :(. I was going to try and use FORSCAN to do it with the raw code. I used the Russian site and typed in a FiST Vin and it populated the spreadsheet like not does for my focus. But idk if I want to load that code into someone's car for fear of bricking it.
Just successfully turned off the Tire Pressure Monitoring System on my 2016 Focus ST using the FoCCCus application.
I got new wheels and tires a week ago and I decided to save the $200 on TPMS sensors.
I couldn't stand the blinking light or the warning message anymore.
Just wanted to drop in and say thanks for this! I'm using the OBDLink LX (Bluetooth) on my 2013 ST3 and it works fine with FoCCCus.
I do have a question though... my speedometer is off a few MPH when driving 60MPH. My tire size is 245/40 ZR18 (93Y), but 245/40 isn't an option to select from for #51 (Tire Circumference) nor #70 (Tire Dimension). Which option should I choose for #51 and #70?
I don't remember what sizes the other options were, but if any of them are taller than the OE 235/40R18 use that one. As your 245/40R18's are taller and wider that OE. So if I'm correct your speedometer should read that you are going slower that you really are.
Hey guys just wanted you to know.
That I'm a tech at a Ford dealer and I just recently figured out how to change as built data with the Ford IDS(diagnosis software) and you can enable global open close windows, change the tire/rim size for the abs module, change headlight bulb to hid/xenon. And more! So for any reason the Focccus app isn't working for u (like for me, i think it wasn't working because I had windows running on a Mac.) just know those things can be changed with the ford software at any Ford dealer with the switch of a button. Very quick and easy.
Yup just had one of the techs at my work enable the global open/close for me yesterday. I had to help him find it but once we figured it out super quick and easy!
I'm a Ford tech in Ontario Canada and our version of ids doesn't give us many options to switch, global windows being one of the ones we can't access. ��
