First tune/data log.....any advice or input?
2.4K views 6 replies 6 participants last post by  MikoST
#1 ·
Hey everyone,
Just tuned my 13 ST3 last night and ran a couple data logs today. Haven't messed with any logging parameters, so I'm sorry if it's not correct. Never used this thing before and still learning the tricks. I am using the Cobb AP3 with the OTS stage 1, 93 octane, latest version (v320). I know a fair amount about engines, but some of this data is way over my head. Could someone take a quick look and verify that nothing seems out of whack? I am running this as my daily driver and would like to have some peace of mind.
Side note, holy hell, I couldn't believe how much that tune woke the car up. Nice job, Cobb! :big smile:
Thanks in advance for the help!
#3 ·
you should record more data
here's my list:
Time (sec),Accel. Pedal Pos. (%),Actual AFR (AFR),Airflow Mass (lb/min),Boost Pressure (PSI),Charge Air Temp. (° F),ETC Angle Actual (°),Engine RPM (RPM),FRP Actual (PSI),Ign Corr. Cyl1 (°),Ign Corr. Cyl2 (°),Ign Corr. Cyl3 (°),Ign Corr. Cyl4 (°),Ign Timing Cyl1 (°),Knock Count Cyl1 (#),Knock Count Cyl2 (#),Knock Count Cyl3 (#),Knock Count Cyl4 (#),Load Actual (%),Oct Adj Ratio Lrn (Mult),STFT (%),TIP Actual Abs (PSI),WGDC Actual (%)
