Not sure if this is under the right section or not I recently bought a 2017 Ford Focus st and got ran off into a ditch smashed the bumper and intercooler fixed what I could and drove the car 3 days later the car started only building 14psi (usually build 16) through all gears then on the highway cruising in 6th I stepped on the gas and at 4K rpm the boost cut and I lost pressure through all gears only building 4psi and the check engine light came on read the codes and it was a loss of boost pressure code after this I went to the Ford dealership and they said the cars check engine light was on because the AGS (automatic grill shutters) were gone after hearing this I filed with insurance and got the car fixed proper at a body shop everything that was damaged replaced and the AGS put back on and they cleared the check engine light for me after getting the car from the body shop I still only build 14psi and when cruising on the highway I step on the gas and once I hit 4K rpm the car cuts boost I only build 4 psi and the check engine light comes on. What is wrong with my car????
