1 - 5 of 5 Posts
Hi guys normally I would spend some time looking for an answer but I just had this thought right before going to bed.
I don't like the DRL's, at all. I am totally okay with not having them if that's what it takes to make this work. It seems like there isn't really a way to not have the DRL's on (end when the lights are set to off??) without using the focccus app. Would it be possible to use some sort of ballast to give me the power I need to run a dash cam?
Reactions: Javierorzco
You're welcome. Although, I did write that up; I just used the procedure and it works great.
1 - 5 of 5 Posts
