1 - 5 of 5 Posts
ok guys I have a question regarding WMI injection points. I am going to be using the 4 port direct injection with the Steeda manifold spacer and my question is should I use smaller size injectors since I am doing 4 ports or just get 3 more of the same size? with my HP range I am to use size 3 injector so should I get 3 more size 3 injectors or get 4 smaller sizes?
Yeah 4 size 3 injectors would be mega overkill. You could crank down the pump, but you'd be getting poor atomization. I'd probably go with 4 size 1 injectors and even then you'll have some headroom.
Thanks for the advice guys, going to try and get a hold of Snow Performance to see what they say
Sent from my SAMSUNG-SM-G935A using Tapatalk
1 - 5 of 5 Posts
