1 - 9 of 9 Posts
Just installed a COBB catted down pipe and have engine light now, from reading the forum sounds like this is normal?
I can't imagine I'd have to live with an engine light? There must be a fix?
Thanks.
The fix is to either tune to get ride of the code or get a defouler (Which is basically a spacer) for the rear 02 sensor to trick it into getting valid values.
Thanks guys, code reset, if it pops up again will add the defouler.
2013 Oxford White Focus ST3
Does the J style O2 sensor restrictor AKA de Fouler go in the front O2 sensor or the O2 sensor towards the rear of the car?
Cool, cause that where I put it with the smallest defouler
Well it has only been 24 hrs, but I can confirm that there has not been a code thrown in either of the ST's that we install the Vibrant J Style O2 sensor defouler in. Both ST's have the CNT Racing catless down pipe and both ST's are running MBRP Exhaust with a stage 3 map from Cobb. So far so good. We also used the smallest of the 3 defouler insert that was provided.
if you need to pass inspection, check your readiness monitors (troubleshooting menu on AP). In most states, you can only have 1 readiness monitor "not ready". Just FYI
1 - 9 of 9 Posts
