I just had my 2016 Focus ST with 106.5k miles have a diagnosis at a shop for coolant loss and white smoke at start up. They did a compression test, all 4 came back 150psi exactly , the coolant system held 20psi for 30 minutes . No leaks. They suspect a leak from the water jacket going into an exhaust port is causing this. The heavy smoke stops after abt 15 seconds. And the smoke stops Completly at around 150 to 170 degrees oil temp. Smoke happens only while idling and deceleration. I’m going from Max to min coolant in about a week of daily driving. I was thinking based off some research it could be a bad water pump seal maybe. Since the car has run dry of coolant at one point from when a hose popped off and I didn’t know till I got home. ( months ago) . Any ideas, cause I really hope it doesn’t need a head. Also, I’m scheduling tommorow to have my local trusted ford dealer to look at it. See what they think. This is a video of the cold start, and excuse my annoying dogs lol.
https://www.reddit.com/r/FocusST/comments/u19hpb
