1 - 17 of 17 Posts
Ladies and Gents,
I'm having this concern because I don't know of it's normal or not. I noticed this whistle sound (attached video). It's audible whenever I rev it up then right after I let go off the gas.
Whistle sound
Thoughts?
Thanks a lot!
That is the turbo blow off valve/bypass valve venting back into the intake/atmosphere. Completely normal for turbo vehicles.
Reactions: Ricky STeamboat
If you put a closed top back on filter box you won't hear it.
Reactions: AwesomeSTr
2016 Focus ST3
Thanks a lot! This is my 1st turbo car so generally clueless . 😅
here is a question.
Don't you like the sounds its making? or does it seems like somethings broken?
‘13 Focus ST3, Tuxedo Black
Ric Flair BOV?
390129
Discussion Starter #10
Installing a good bov will eli
here is a question.
I don't like the sound because it feels not normal to me.
If putting a bov would eliminate this then I guess I'll get one.
A blow off valve will not eliminate the noise, it will make more noise.
2016 Focus ST3
BOV sound is way different from this one. If I could just make it not sound like this and hear a BOV instead.
You have an RS intake cover which helps in hearing that sound even more. Get a closed cover for the intake and you wont hear much of it, when the hood is closed.
I suggested the same thing back on post # 3, apparently that is not a consideration.
Reactions: W4R and xTheMan42
2016 Focus ST3
2016 ST2, Absolute Black, Turbosmart BPV, Dual OCCs, Innovative RMM, JBR Intake & SS Arm, 245/40R18
Just remove the intake and put a screen over the turbo 🙄😛
1 - 17 of 17 Posts
