So the other night I'm driving to work, cruising about 110 on the Hwy. All of a sudden it feels like I have a flat, so I turn the radio down and drift around the lane thinking it was the uneven pavement but then I see the check engine flashing and I've got no power. So I get off immediately (convienelty there was a exit right there) and barely Make it around the exit and see a small parking lot. I pull in and scan the ecu and get a misfire in cylinder 4 code. I switch the car off and turn it back on and it sounded like a lumpy Subaru idling and I heard some metal grinding sounds. I immediately shut if off and called for a tow...two tow trucks later (the first one didn't have wood to load the car on the flatbed) I get back to the shop I do some part time work at.
Next day we pull the coils and spark plug and scope the cylinder and sure enough a piece of the piston is broken off and the cylinder walls are scratched. We checked cylinder 1 and it shows some small scratches too. At that point we parked the car and I left it till I decided what to do.
I called my ford service manager who is a pretty good guy when it comes to mods but he said if there is internal engine damage they have to call a ford investigator and if he sees any mods he will void the warranty. When I told him I had a fmic he said for sure they will void it. And if I put back oem stuff they would be able to tell. Problem is I could put the stock tune back in but I can't drive the car to get any drive cycles on the car. So figuring I would save myself two tows, one to the dealer and one back plus the money for the dealer to diagnose the car I would just build the engine with my mechanic buddies help.
Car is modded as follows:
Torrie 93 tune
3" carted turbo back exhaust,
Upgraded fmic
Eibach pro-kit springs
Mountune upper strut bar
And a few other suspension pieces
Car has 46000kms and is a 2013.
So now I'm trying to decide what is the best way to rebuild and prevent this from happening again.
Speed performance makes a nice rebuild kit with all forged internals
Dead hook Motorsport also has some nice pieces
Both are Mahle forged pistons and connecting rods
Sorry for the long Post continued...
Torrie 93 tune
Upgraded fmic
