1 - 4 of 4 Posts
@beaSTin16
So OE is a 18X8 +55mm
The wheel you have chosen without any spaces would sit out 32mm more than OE (1.25 inches). So add what thickness spacer you are getting to the 1.25 and that is how far it will stick out. In my opinion it will be to much as you probably have to get at least .75 inch spacer to accommodate the lugs + studs. Not counting you'll have to cut the studs short to fit.
1 - 4 of 4 Posts
