1 - 7 of 7 Posts
I stopped at a mobil and put 10 dollars 93 in the tank, about 15 min later driving on highway i went to accelerate and it starts stumbling like a misfire. Very light throttle its fine but as soon as you give it a little gas it will shake and stumble. at idle it sounds like a misfire and engine runs rough.
I checked the intercooler hoses and everything seems connected. i tried scanning engine with cobb tuner and didnt get any codes.
I flashed it to cobb stage one 87 octane and it seemed the same.
should i drive it or let it idle for a code to pop up?
should i scan it with my scangauge?
should i pull the plugs and check them? they have about 20k.
should i add octane booster?
44k stage one
fswerks intake
mbrp catback
one step colder plugs
stratified 93 tune.
car was parked at work over the weekend as to i did not want to risk anything happening as to my commute is 45 min.
44k stage one
fswerks intake
mbrp catback
stratified 93 tune.
I'd check the plugs first, easiest thing to do. It'll take 15 min.
Reactions: oVrKiLL
Bad gas. I would baby it until its time for a fill up. I wouldn't bother trying to chase down any other possible issues until you run through this tank of gas.
Thanks for the insight. Ended up being bad plugs. All of them were gapped at .040 instead of .026. Had about 20k on them. had denso's replaced with ngk's
i added some octane booster while i was changing the plugs just to be safe
It runs and idles perfect again.
This car is so susceptible to bad plugs/bad gaps. It's totally worth inspecting the plugs/gaps at every OCI.
Still waiting on mine...last time I order something that isn't a prime item on Amazon lol my car is running like absolute donkey sheet. Where those new ones @ tho :rolleyes:
Reactions: BCE22
1 - 7 of 7 Posts
