1 - 20 of 97 Posts
2016 Focus ST2
Hello Everyone!
I bought my ST new and it has been with me since then. I kept it mostly stock until the warranty ran out. I had all those common issues our platform suffered from and got most of them fixed under warranty.
I love the car and I actually started spending more 馃挵 around 75K miles when my stock clutch failed. The car has 95K miles now.
It was tuned at 80K and ran stage 1 for few thousand miles. The car is driven daily like it was just stolen (after warm up)
I consider myself lucky since there is plenty of information on this forum which helped me decide which parts to use and which ones to avoid, So I hope this thread helps others too in deciding which parts to use.
I will try to document install and other information I gather here.
A lot of people want to make as much power as they can but forget one crucial thing, how are you going to put that power down? My goal is to make sure whatever HP the car makes translate to the road.
This thread will serve as a log, its hard to keep track of all the parts.
2016 Focus ST MM ST2
ENGINE
JSTUNED Stage 3 ALAN from Edgeautsport Tune
Radium Engineering Dual Catch Can Kit
Radium Engineering PCV Baffle Plate
Steeda Symposer Delete
GFB Diverter Valve DV+ HKS BOV
ATP Intercooler
Cobb 200 cell downpipe
Forge wastegate Tial wastegate with 3p dump tube
Vibrant 11620 J-Style defouler
SUSPENSION
Eibach Focus ST Sway Bar Kit - Front and Rear Combo
Damond Motorsports Focus ST Full Motor Mount Set
JST Performance Grip Stabilizer Bar
TB Rear Bar
MOOG Control Arms
Mountune Clubsport MRX Adjustable Suspension Upgrade
Steeda Focus ST Adjustable Rear Endlinks
Steeda Focus Adjustable Front Sway Bar Endlinks
StopTech Sport Rotor High Carbon FRONT 335mm
EBC YellowStuff Brake Pads
TRANSMISSION
ACT HD Clutch Kit
Lightweight Flywheel ACT
MOTUL DCTF
Carbon Synchro Kit
MFactory LSD
JBR Focus Short Shift Arm
JBR Solid Shifter Base Bushings
Solid Transmission Cable Bracket Bushings
JBR Counter Weighted Shifter Cable Bushings
Boomba Shifter Cable Bushings
EXTERIOR
JBR Rear Wiper Delete
Smoked Sequential LED turn signals
Wiper Delete
RS WING color matched (coming soon)
This thread will be updated with pics soon. I am sure I missed few parts which I will add later.
385935
and the reason its called "Yoda"
385936
2016 Focus ST2
Finally the LSD is here.
After 3 and half months, this part was holding up all the other installs!
Originally I ordered MFactory, Vendor never delivered, saw other people getting their LSD's in 3 days from Taiwan. Cancelled wavetrac ordered MFactory.
385886
Hoping to get it installed by Friday, need to kick @DJFreshlySnipes ass this Saturday. :cool:
@wingnutt you stay away from me please 馃槵馃い
Good luck! Maybe that LSD will prevent you from flicking rocks into my windshield this time
A white FSwerks Tuned, Steeda Breathing, Straight Piped, Symp Deleted 2015 FoST-2 wrapped in Indy 500鈥檚. - SD
2016 Focus ST2
Discussion Starter · #10 ·
Did you get a chance to see my front tires? 馃槵
its okay you have a white ST rock chips dont show as much :cool: 馃槄
Reactions: TurboGT
2019 Mustang Bullitt
Oh yes they do. Plastic is black behind the white.
Lol
2016 Focus ST2
Discussion Starter · #13 ·
I thought I had everything the mechanic would need to install the LSD but apparently need a new one of this.
Output shaft bearing?
waited months, I can wait until after XMAS.
386149
2018 blue metallic
I am a bit confused. Did you order wavetrac and not get it and then order mfactory ? I was gonna go wavetrac thru fswerks and then saw mfactory for 699 thru maperformance. Either one of these outfits reliable for delivery ?
2016 Focus ST2
Discussion Starter · #15 ·
I had stock related issues.
either one of them is fine and does the job.
2016 Focus ST2
Discussion Starter · #16 · (Edited)
Something always has to come up last minute and ruin it all.
My mechanic called me to tell me the synchro kits 1 and 2 dont fit.
He sent me this picture and told me the others fit perfectly.
Was I sent the wrong synchros?
386360
386361
386362
Also I need an input shaft seal 7025A, any idea where to get it?
2016 Focus ST2
Discussion Starter · #19 ·
What's the problem?
Which synchros did you buy?
Yeah you need 4 bearings for the lsd/synchro job. One on each top of the countershafts, and the 2 on the differential. Also new ring gear bolts and output seals. Not to mention shims for the LSD. Which I doubt most shops actually shim it out for preload.
I bought this Jacks Transmissions
and mechanic says I need these
386366
386367
1 - 20 of 97 Posts
