Are you sure you aren't dropping rail pressure? You're running out of fuel, so you're FRP isn't high enough, your injectors aren't modeled correctly for those pressures, etc.
It's hard to really know the whole story because the log is missing boost and FRP, etc.
If you're exhaust was leaking pre-oxygen sensor you'd actually see a false rich reading as oxygen makes its way into the exhaust. It'd also probably not be RPM dependent.
Boost leaks also tend to go rich as air that it thinks it had wasn't actually there. On this car it's not as likely though because you'd have to leak post throttle body I believe for that to happen. (Or maybe it's pre-intercooler? I can't quite remember).
Your HDFXs are also incorrect. Do you have the latest alpha download from COBB? They fixed the HDFX table values. Your's add up to far beyond 100% and oscillate far too much.
@COBB would I be right in assuming this isn't the latest firmware? It almost looks like the gain on the value was too high and it overflows and wraps back around.
