1 - 9 of 9 Posts
Trying to figure out what could have caused this.
I recently got some more data logs for the hell of it. I used the same road I always use, same temp outside, same mods. On these logs I'm showing about 20 less hp and 20 less torque than last year. I made sure the weight was the same in vdyno. Still hitting full boost (23-24psi).
Only thing I changed was I now use an aem dryflow filter instead of the stock paper filter. Wondering if I should do a compression test? Engine feels healthy and nothing seems off besides the vdyno numbers.
The engine is bound to lose power over time, but 20% per year seems excessive. A compression test could not hurt.
Look at your spark plugs, the ST is not very plug friendly it seems.
Same fuel, last time spark plugs were changed and GAPPED properly (<- highly neglected super important one), anything tune wise changed at all?
I'm running itv22 plugs, but my tuner says he prefers stock plugs. I'm just worried about going back to stock plugs when running that much boost.
I think something changed with the latest version of vdyno. With the old version my car showed more power when my car was stage 1, than it does now at stage 3 with the newest version.
I actually just changed the plugs about 5k miles ago and gapped them correctly. The itv22 plugs that I pulled out looked great too.
You know what, I was thinking this too. But didn't want to blame it on that.
1 - 9 of 9 Posts
