1 - 4 of 4 Posts
Vendor
Land vehicle Vehicle Car Automotive design Hatchback
An update for the Focus and Fiesta ST platforms is now available. This update includes v501 maps which contain minor feature improvements and bug fixes from the previous release. Also included is an update for the Accesstuner software which addresses bugs and simplifies features.
Version
AP3-FOR-001: 1.7.3.0-14467
Improvements
Reverted the "Gear Shift Hang" change from v500. (Fiesta ST only)
Enabled Fast Flash Capability - Map changes should now be quicker within the same generation maps. Example: Gen1 v401 reflash, followed by Gen1 map revision. Gen2 v501 reflash, followed by Gen2 map revision. Changing between Gen1 to Gen2 maps will require a full flash.
Fiesta ST V501 Maps
- Map Notes
Anti-Theft Mode v501.ptm
Stage0 v501.ptm
Stage1 91 OCT or 95 RON v501.ptm
Stage1 93 OCT or 98 RON v501.ptm
Stage2 91 OCT or 95 RON v501.ptm
Stage2 93 OCT or 98 RON v501.ptm
Stage3 91 OCT or 95 RON v501.ptm
Stage3 93 OCT or 98 RON v501.ptm
Valet Mode v501.ptm
New Monitors
- Ford Monitor List
EOI Actual - Actual End of Injection for the current effective intake pulse in degrees before top dead center.
Bug Fix
Fixed an issue for vehicles that may have exhibited a "P061A" code (Fiesta ST only)
Accesstuner Updates
Version
Accesstuner - 1.9.1.0-14467
Improvements
CCF RPM Feature Simplification
Simplified configuration for LC. LC Master Switch will now auto-enable 5-way Hard/Soft limiters where supported.
Removed LC Hotswap "Offset" tables and switch. LC Hotswap no longer requires this component and is automatically handled.
Simplified configuration for FFS. FFS Master Switch will now auto-enable 5way FFS limiters.
Simplified configuration for Driving Limiter. Switch removed, 5-way always active.
Added familiar "Switchable Map X" to CCF Map Switching Sub Folders
Restored (read-only) vehicles to full functionality, renamed to (CCF Gen1)
All vehicles supporting the latest Realtime and Speed Density features are labeled (CCF Gen2)
Added "Copy Tables" functionality to CCF Gen2 vehicles
See Ford COBB Custom Features - Accesstuner Definition Upgrade Strategy
New Monitors - Ford Monitor List
Bug Fix
Fixed an issue that prevented (CCF) 2D and 3D tables from initializing from default map slots greater than 1
Bug applies to maps saved by 1.9.1.0-14401 with the latest "COBB Custom Features (Gen2)" strategy. To apply bug fix, simply open and re-save any impacted map in 1.9.1.0-14467.
Vendor
Discussion Starter · #2 ·
There is an additional update now available to fix a few issues present with this release. The current version of maps is now v503. The fixes include
Focus ST Bug fix for Catalyst Temperature calculation.
Anti-Theft calibration fix/improvement for FOR-001.
Grille Shutter U0284 DTC fix for Focus ST maps.
Map Switching Notifier improvement.
Quick question for you... I purchased a used AP3 and it was running V.312, I have since updated to V.501 - Would there be any reason to re-flash the ECU?
1 - 4 of 4 Posts
