· Vendor
If you feel that your Ford Focus needs more power to pass the slower traffic on the highway, replace your stock downpipes with Stainless Works 304 SS Downpipes with factory connect. Whether you choose off-road version or mill cutted downpipes, you are guaranteed to get increased performance and improved sound. Featuring high flow catalytic converters, these downpipes completely replace your factory downpipe and power robbing catalytic converters. Built from 3 in. diameter T304 stainless steel tubing, they are strong and have superior corrosion resistance.
Features:
- 3" Diameter Downpipe
- Stainless Steel Flex Joint
- V-Band and Two-Bolt Flanges
- 304 Stainless Steel
- TIG welded for strength
- Mandrel bent (no buckling) for optimal flow
- Factory Connect easily mates to the factory connection point.
Stainless Works® 304 SS Mill Off-Road Downpipe with Factory Connect
Stainless Works® 304 SS Mill Catted Downpipe with Factory Connect
Make sure to check our post about Stainless Works Cat-Back Exhaust System.
Get the most out of your Focus with Stainless Works Downpipes at CARiD!
