1 - 13 of 13 Posts
So I have a Turbosmart 50/50 that I installed about 1 year ago. Its beginning to stick open while driving normally. Is there any way to remove or lubricate? Also im not a big fan of the BOV venting at low boost would I be able to install a boost controller between the vacuum line in order to control just the boost required to open the BOV. Would that damage anything or prevent turbo from going past set boost level?
· Premium Member
I don't think that it would damage anything by getting stuck open honestly, but if I were you I'd contact them about it. I know Boomba is really keen on getting stuff like this resolved, and I wouldn't be surprised if they also were.
I was referring to installing the boost controller between vacuum line to the BOV. You think that would damage anything?
· Premium Member
The valve needs to be able to vent any boost even 0.5 psi when you let off. So yes that can be annoying. I would add another controller. Vehicle specific valves are designed for the oem vacuum source. So I wouldn't mess with it personally. If the valve is sticking follow the cleaning guide posted above.
Sent from another garage.
Discussion Starter · #10 ·
Run it off a symposer delete. Its a true vacuum source and eliminates most of the early pop off issues
Ya I didn't get the one with the vacuum port. Didn't think I would ever need it. Anywhere else I can run true vacuum? I mean I could just drill and tap but im not sure my harbor freight tap and die can handle it...
Could you buy a MapTap from cp-e and use that as a boost reference? @UnfocusedST
Reactions: UnfocusedST
· Premium Member
Yes. However if you do that you need to make sure the valve is closed during idle. It won't pull air in. However it can add lag to boost building and cause idle issues.
1 - 13 of 13 Posts
