Just wanted to share our timeline as we work through the SCT software for the Focus ST. First off the motor is extremely stout down low and throoughout the mid range. What it seems to be lacking is more power up top. The low end torque throw you back in the seat and pulls strong mid way through the powerband. After that...pppphhhhhhttttttt falls on its face.
Our initial testing one the Bosch ecu confirmed a few things we had already learned from previous Bosch ecus of recent. Anything with a turbocharger from the factory is going to have an extreme amouynt of torque management implemented. We loaded the SCT tune that is being sold by other vendors and low and behold it netted what some had thought esspecially COBB. Their statements caused some extreme conflict when the went head to head in their own test versus the SCT tune. First off I agree with Trey Cobb 100% stating that the Torque limits were restricting power. Having a few years with Bosch & Siemens ecus which implement these tactics, this was the first thing we searched for in the SCT software. TA DAH...plenty of tables there to work with for increasing the factory torque limitations. There actually overall as well as individual limits based on gear and throttle request etc....
What we notice is that the car makes the same power run after run with either the 3" exhaust, 3" DP or our intake. Only variance was about 10-15 ft lbs of torque. overal HP stayed in the same range. In fact on the runs where the car was making additional power the ecu pulled so much timing that the AFR richened up quite aggressively. This happened right where peak HP was at and the power dropped below stock levels. This is why so many to date have tried to put on exhausts and DP and not made significant gains. What it boils down to is COBB or SCT dont even both putting a part on your car without a reflash that incorporates torque limit increases. Most recently we built an intake and exhaust for the new Audi S6 twin turbo. and ran into the same issues. Car showed decent increases but after driving around for a couple days and going back onto the dyno it was making the same power as stock. Word to the wise car manufacturers are allot smarter than you think. They're not going to give you a loaded gun :cool2:
We will hopefully concluded our testing tomorrow. Im spending the night editing a map and going over todays datalogs to get a good starting base tune tomorrow.
