1 - 4 of 4 Posts
So I've had a chance to play around and get some readings with this app. I'm not sure how accurate hp/tq numbers are or if there is a specific gear you should be in to get the most reliable data but here are the specs so far, I know I can do better on most of the times. I also posted other screenshots in the pid thread:
308 WHP / 300 WTQ
258 WHP / 294 WTQ
0-60: 6.36 sec
40-60: 2.37 sec
60-80: 2.8 sec
80-100: 3.9 sec
60-120: 114.4 sec
1/8 mile [email protected] mph
max boost: 21.8 PSI
MAP: 30.5 @ 96% load
Timing Adv Cyl1: 61
Discussion Starter · #2 · (Edited)
So what are the factors that determine the accuracy of the torque pro app for calculating hp & tq from vehicle sensors vs. using an actual dyno? Has anybody compared the two and what was the difference, if any, in the data collected?
Did some runs with obdlink and got the following stats
This is prolly more realistic i was able to get a good rolling pull from 3k in 3rd through a solid 4th to redline up to 5th before i ran out of room.
1 - 4 of 4 Posts
