I purchased my Torque Solution RMM in September of last year. Installed it, and was immediately happy with the results. The 1-2 bang/clunk was immediately gone, and wheel hop was greatly reduced. Fast forward to last month when I installed my new downpipe and exhaust. The install went well and I though nothing about it until I went to start the car and heard a sort of clunk. I get back under the car and notice that there is very minimal space between the downpipe hangers and the front subframe, but as it sits they weren't making contact so I left it alone until today. I was working on the car today trying to adjust the downpipe so that it didn't hit the subframe, and I noticed that as I pulled on the downpipe, the engine would move a little bit. So I unbolt everything and pull out the RMM, and it falls out in pieces. The center holes in the bushings are so wallowed out and misshaped that the sleeve that goes between the two just falls out. There is a substantial amount of material missing from one of the bushings, and if you flex it any, you can see that there are multiple cracks in the material as well.
I'm not trying to knock Torque Solution, because I have owned a few of their other parts for the last couple of years, and have not had any issues until lately. Last month I also had an issue with their shift cable bushings not being the right diameter to accept the OEM bolts, but that's a different story. On their website they say that they have a "Limited Lifetime Warranty", and I emailed them today and included some pictures as well. I just wanted this to be a heads up to any of you that may be using their RMM, not saying that they all are bad, but you may want to go out and check yours.
