1 - 3 of 3 Posts
No boost leak found...bad WG actuator??
So went to the dyno the other day...On the way to the dyno I logged in 3rd gear and hit 28psi and everything felt great. Fast forward to the dyno and the car runs crazy rich and only hits 22psi.
Tuner says check for boost leak so I do and don't find anything. Even tested it up to 30psi. What else would cause my WGDC to be 100% and my boost to only hit 22psi?
I have attached the pre-dyno log and 1 log from the dyno. Could my wastegate or actuator be messed up or faulty? I'm lost right now.
Any help is greatly appreciated!
Thanks
View attachment 2013ST_2971_Aux.zip
You're SOL.
Gotta sell the car now.
What you parting out?
Sent from my XT1650 using Tapatalk
Everything aftermarket will go!! LOL
Reactions: Nionetics
1 - 3 of 3 Posts
