I legitimately laughed out loud at this comment!Yes. Read your owners manual.
I agree I laughed too. Good use of harshness.I legitimately laughed out loud at this comment!
http://www.focusst.org/forum/introd...s-ask-anything-not-get-flamed-thread-374.htmlHi Everyone, do the 2016STs have a tire pressure monitor?
I think that is useless...lolIt doesn't seem to tell you what the PSI is tho. My 2015 f-150 does on each tire, but my 2016 Focus can't? Unless I am an idiot (good chance) I think that's b.s.
Knowing which tire is low is useless? Okay.I think that is useless...lol
I guess that makes sense, and I am coming from 10 ply truck world. You can't tell as easily on those tires which one is low, especially if it's only a few psi. The real advantage to knowing how low, is I can tell if it's just weather change, or if I actually have a leak. Now you can tell all that by getting out of the car and measuring the psi etc... but I guess I am lazy and want a computer to do it?Good chances if your tire is low enough to throw the light on...you can see it visually.
Dude...that's not how it works. The PSI on the tire is the MAX PSI the tire can take and that's dangerous as hell to run them at max PSI. The PSI you should be running on your tires is on a label in the driver side door jamb or on the door itself. I can't remember the location.It doesn't seem to tell you what the PSI is tho. My 2015 f-150 does on each tire, but my 2016 Focus can't? Unless I am an idiot (good chance) I think that's b.s.
WTF are you talking about. Obviously I'm not running my tires at 80psi you clown, I am talking about monitors on the truck, nothing about max psi. I actually never mentioned the tires...Anyways the info is on the door jam towards the back of the seat, it recommends 36psi for the focus. Thanks for your inane response tho.Dude...that's not how it works. The PSI on the tire is the MAX PSI the tire can take and that's dangerous as hell to run them at max PSI. The PSI you should be running on your tires is on a label in the driver side door jamb or on the door itself. I can't remember the location.
Settle down, buddy. I read your post that I quoted as you're getting you're tire pressure info off the sidewall of the tire. My fault. No need to go all prick mode.WTF are you talking about. Obviously I'm not running my tires at 80psi you clown, I am talking about monitors on the truck, nothing about max psi. I actually never mentioned the tires...Anyways the info is on the door jam towards the back of the seat, it recommends 36psi for the focus. Thanks for your inane response tho.
You guys are funnySettle down, buddy. I read your post that I quoted as you're getting you're tire pressure info off the sidewall of the tire. My fault. No need to go all prick mode.
Not really....Personal experience with my 2016. (One of the tires developed a VERY small leak which I had road hazard protection on). TPMS kicks in at approx 28psi. That is really not enough to visually detect. Get a good tire meter because TPMS won't tell you which tire it is, so you have to make the rounds.Good chances if your tire is low enough to throw the light on...you can see it visually.
I agree I was a bit aggressive, but I said I was an idiot, not a retard so I was a little miffed at how dumb you thought I was! Either way NBD and not worth fighting over! Enjoy the weekend!Settle down, buddy. I read your post that I quoted as you're getting you're tire pressure info off the sidewall of the tire. My fault. No need to go all prick mode.
Right on. The problem is there really are people that are that dumb. I used to do tires and I've seen a bunch of crazy stuff.I agree I was a bit aggressive, but I said I was an idiot, not a retard so I was a little miffed at how dumb you thought I was! Either way NBD and not worth fighting over! Enjoy the weekend!
You'll see it visually.Knowing which tire is low is useless? Okay.
