1 - 20 of 24 Posts
Hey all,
Looking for some suggestions on tire/wheel packages, and what tires you think are best for DD. I plan on buying some summer wheels and tires, and using my stock premium wheels for winter (New York).
I really like the look of the Niche Targa, but I also like a dark bronze wheel as well. Not looking to spend more than $250 a wheel.
Any advise and opinions are appreciated! Pictures too! I’m driving a 2017 ST Absolute Black.
The wheel is super dependant on personal preference, so it's hard for me to make a suggestion. My best advice in this scenario is consider the diameter with your budget. A stock size tire (235/40/18) is going to be much more expensive than a similar size tire on a 17" wheel, since a ratio of 40 on an 18" is considered low profile, but a ratio of 40 on a 17" tire is not. As far as tire brands are concerned, the Continental ExtremeContact is a great performing midpriced tire. The Michelin pilot sport 4 is a bit more expensive and slightly better than the Continental. I've heard nothing but good reviews about the Firehawk Indy 500 as a low budget summer tire, but I can't personally vouch for it.
Sent from my LG-LS993 using Tapatalk
Discussion Starter #3
Awesome thanks!
Discussion Starter #4
Anyone running 18x8.5 on their ST? Wondering if any rubbing occurs with coil overs.
It will also be dependent on the offset of your wheels. Anything +47 or lower should be okay in terms of inner wheel to coilover perch clearance. Once you go up to +48 you start to run on the hairy edge of rubbing on coilovers especially when you run 255's or wider on a 8.5 or 9 inch width wheel.
Reactions: redSerpent
Discussion Starter #9
Thanks! The wheels I want are +42
I've had a set of Konig Oversteers on my car with a set of Cooper Zeon RS3 G1s for the past 2 years, and loved the combo. I'm also lowered on ST-X coil-overs. No rubbing, buy my wheels are only 18x8, and the stock tire size. I'll be getting a set of Achilles ATR Sport 2s this week to run for the summer. They are super cheap, looking like $273 shipped to me from Walmart. I'll see how those hold up, and plan to go back to the G1s once these are used up.
I just put a set of Niche Misano wheels in 19x8.5 with +40 offset on my DD. But those might be a touch out of your $250 per corner budget...
Another vote for Konig Oversteers. Mine are stock size (except for offset, which is +10mm) shod in Michelin Pilot Sport 4 S's. The Michelins are sublime. I doubt I will ever put anything else on my ST.
The Oversteers were $598 for all four, shipped to my door. I purchased aluminum hub rings, and 20 new lug nuts.
The tires were $866 out-the-door.
Discussion Starter #15
I ended up getting 18x8.5 +43 Konig Lockout’s in gloss black. I’ll post pictures next week when I get them!
I gotta admit, I love the Shadow Black ST & am tempted to buy one. Can you use a spray detailer & micro fiber on that paint without streaks & smears?
Discussion Starter #17
Yeah, I use ChemicalGuys eco smart and it works great
Yeah. I’ve been using Chemical Guys and F11 on it for the past year... before that I was water washing, and still do every once in a while if the buildup is excessive...
I live in a rural area with lots of gravel roads so the grime can cake up pretty fast.
Just a word of advice about the aluminum hub centric rings. Hopefully you don't have the same issue I did, but I bought a set off of eBay, and 2 or 3 of them became lodged in the wheel, and I had to split them in half in order to get them out.
I'm running these Motec MCR2 Ultralight in 18x8 with Nitto NT555 G2's on them.
The wheels are fantastic. Coming in at a low 8,7 kg each (19,2 lbs) and they had cost me $225 a piece.
The Nitto tires were dirt cheap at $85 each. Would I buy them again? Idk. Maybe. Response, wet handling and such are great, but they're a bit loud and imo lack a bit of dry grip. Will try the new Goodyear Supersport R next year.
1 - 20 of 24 Posts
