Take off the cowl before you do anything else. Opens up the entire engine bay, even let's you access the negative battery terminal.
Don't forget to be liberal taking photos, 3x as many as you think you need. Especially harness routing, all that stuff. It's easy to do and makes figuring things out a LOT easier going back together. And don't forget lighting for the photos. The thing you need to see in detail seems to always be in the background in the darkIt’s officially time to start swapping. Anybody have tips or suggestions with anything? I know there’s some forums already but wanted to know if anyone has got any tricks up their sleeve to help with the swap. Any help is appreciated !
That is exactly how I did it on my 2003 BMW 330i. Just easier that way.front, doing it at home with no lift
Never thought of that. Thanks for the pro tip!Get a big sheet of cardboard and poke bolts into it as you remove them. You can write on the cardboard, so it acts to keep things labeled and grouped. This is especially handy for the transmission bellhoushing bolts since there's a couple longer or odd ones.
Make sure you purchase the big turbo tune right now, so you can have the base map loaded up to the ECM before you start the car.turbo has been ordered. garrett powermax
Who do you run your tune by?Make sure you purchase the big turbo tune right now, so you can have the base map loaded up to the ECM before you start the car.
Both my Powermax and my GTX turbo were tuned by edge autosport.Who do you run your tune by?
Could you post a link with that part?Make sure you upgrade that plastic BPV too! I installed the ford racing unit for the Focus RS when I had my powermax.
