We've run this special every now and again, seems to be a crowd pleaser so we bring it to FocusST.org!
The AEM wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
  • Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
  • Does not oscillate AFR reading like narrow band sensors
  • No laptop required for monitoring!
  • Bosch sensor included
  • Accurate to 0.1 AFR
  • Reads in AFR or Lambda via a switch in back of gauge housing
  • 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
  • Integrated three-digit display reveals AFR or Lambda in real time
  • User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
  • Serial data stream included for output of AFR (RS 232)
Retail - $285.83
THIS WEEKEND ONLY $169.99 Shipped in the US.
