1 - 20 of 33 Posts
2018 Focus ST3
Full power mods list (in order of flow path):
-Generic 3D printed snorkel
-Flowmaster Delta Intake
-G25-550 0.72 AR turbo
-3P hot side charge pipe with Greddy BOV flange
-Greddy Type S BOV mounted on hot side charge pipe
-Levels FMIC
-JBR cold side charge pipe (with meth bung plugged)
-Tial MV-S 38mm wastegate w/ 3P dump pipe
-Mountune sports cat (200 cell count) downpipe
-Thermal R&D catback exhaust (with 3" adapter and Vibrant Ultra Quiet resonator added in)
-Tuned by Alan @EdgeAutosport.com with Cobb APv3
Other mods:
-RS OEM shifter
-JBR short shift arm @ 20% reduction
-Shifter cable, bracket, base bushings
-Innovative 75A rear motor mount
-Radium PCV baffle plate
-Damond stage 3 catch can
-Sound symposer delete
-Hella Supertones
Date of purchase: June 23, 2018
390436
Drove it to the in-laws' house.
390437
I immediately went to my first car meet, filled with lots of STs. I parked away from everyone since I was the new guy.
390438
One of them gave me this.
Day 4: Green Filter.
390439
Day 4: Tinted windows.
390440
Day 5: Sound symposer delete
390441
Day 13: Thermal R&D catback exhaust.
390442
It stayed this way all the way until March 2020.
2018 Focus ST3
Discussion Starter · #2 ·
2020: Lockdown mods
Bored, painted calipers.
390443
My favorite BOV sound: the NGR Type S
390444
I plumbed this pipe into the hot side, routed it to the sound symposer delete.
390446
Dipped the premiums using Gunmetal and glossifier.
390445
Scored a used FMIC locally. Dogs approve.
390447
I am not a free advertising board. Levels logo deleted, FMIC installed.
390449
Innovative 75A RMM
390450
Hella Supertones and 3D-printed snorkel.
390451
Picked up a used Mountune catted DP and adapter from Thermal to make my exhaust a true 3".
390452
Local guy traded his RS wing for my ST wing.
390453
2013 Ford Focus ST
Quite the adventure! Very nice!
Reactions: jwuonog
2018 Focus ST3
Vibrant Ultra Quiet, because peace & quiet is underrated. It took 3 tries for amazon to send me one that wasn't bent.
390454
New hotside charge pipe from 3P Performance.
390455
RS OEM shifter/before after, as well as JBR short shift arm and all the solid metal bushings.
390456
Flowmaster Intake. I liked the airbox design, and the fact that the pipe was plastic (less heat soak).
390457
AP and Sync 3.4
390458
Charge pipe installed.
390459
Knob from Shift Solutions.
390460
390461
Pulled the intake mani to do Radium PCV baffle plate, both Damond catch cans, and tried to clean the valves using chemicals and a shop vac.
390462
How my valves looked at 38k (before cleaning).
390463
2018 Focus ST3
New turbo arrives: G25-550 0.72 AR
390467
390468
This plug can be removed and used as a boost source. No drilling of charge pipes required.
390469
390470
Blanket to keep temps down under the hood, possibly increase spool.
390471
Homemade wastegate tester. TiAL springs are very inaccurate these days.
390472
During the turbo install, I didn't like how the coolant return was being pinched by a protrusion on the block.
390474
I also stupidly kept the metal gasket from the OEM turbo on. Don't do this!
390475
Turbo came off and went back on correctly. Coolant return line routed upwards. Dump pipe connected!
390476
2018 Focus ST3
Discussion Starter · #8 · (Edited)
What a mess!
390477
Turbo install was done alone on jackstands over a weekend. I took my time and lots of breaks. About 12 hours on Saturday, 10 on Sunday. Intake either sits too close to the passenger side, and doesn't meet the filter section, or sits too high and touches the cowl if using the supplied extender.
390478
Wastegate hiding, with insulated vacuum line.
390479
All my favorite sounds come from here: Type S BOV and EWG Dump! The silicone coupler supplied by 3P was just barely long enough. With the big turbo in, it was a stretch. I cut some 2.5" coupler and replaced it here.
390480
Base map from Alan @EdgeAutosport.com on wastegate pressure. Tial's 14.5 psi springs end up hitting 21-22 PSI.
390481
First revision logged. datazap.me | jwuonog | G25-550 v1.01
390482
You going to run Auxiliary fuel? My tune tops out at just under 26 psi on 93 stock fuel. I know about how long the turbo takes to install in stands. I had my car up Friday night ready to go. Saturday in August started at 5am and quit at 7pm. To breaks at all. Back to it Sunday at 9am and finished after 12pm. I did do the waste gate and cold side charge pipe with BOV at the same time though. Also the waste gate and dump tube of course.
2018 Focus ST3
Discussion Starter · #14 ·
As of now, I don't plan to install aux fuel. I may do WMI later but only for the cooling/cleaning. If I do upgrade the fuel, I'd want to go with the HPFP and maybe even injectors.
2016 ST1, FBO, GTX2867R Gen2 .64-AR, Spec stage 2 clutch, Quaife LSD, Fortune Auto 500 coil-overs.
What a mess!
That's a nice flat boost curve! Doesn't it feel foreign to have power until redline? Lol
2018 Focus ST3
Discussion Starter · #18 ·
My tuning is now done. Alan Jackson at Edgeautosport did my e-tunes for both 93 pump and E30. It rained several days since I started tuning, but he was still able to get my tunes done within 2 weeks. The car runs GREAT. When not in boost, it feels just as smooth and mild as stock. When the boost comes in, it pulls hard.
I asked for a safe and reliable tune, since this is my daily. Numbers look great.
Check out my datalogs.
Final 93 tune datalog
Final E30 tune datalog
1 - 20 of 33 Posts
