1 - 16 of 16 Posts
Vendor
You guys have been waiting for a long time, but they are finally available!
Custom Performance Engineering Atmosphere Turbo Kit for Focus ST
Starting at $4053.95
cp-e is nothing if not thorough and thorough is exactly what they were when designing and manufacturing this kit. If you are looking to put a garrett turbo on your car, it doesn't get any better than this.
This kit comes with an exhaust manifold specifically designed with Tial flanges to fit Tial VBand Turbine Housings from GT28-GT35, and Tial MVR External Wastegates. It comes in cast 304 stainless steel, and is designed to allow for the most efficient exhaust flow possible from the engine to the end of the downpipe. Protecting the manifold is a laser cut and CNC bent heatshield that fully encompasses the manifold. This heatshielding holds the heat in the manifold to keep the engine bay temperatures down, and eliminate the need for wrapping the manifold. cp-e™ even provides an extra O2 bung and EGT bung on the manifold if you need something to plug sensors into. Yes, even those bases were covered.
A common setup for the turbo bypass is to use a screamer pipe, which dumps the exhaust to the atmosphere immediately after the exhaust manifold. This practice is lackadaisical at best, so cp-e™ has taken the extra time and effort to divert the exhaust correctly. The cp-e™ DownScream™ Downpipe diverts gases straight into the exhaust pipes to be expelled out of the rear of the car. Having this setup keeps your high boost events quietly intense, rather than noisy and agonizing. cp-e™ has designed this downpipe to keep your system within a legitimate decibel range while still providing the proper flow for any size turbo you want to put on the car.
One of the shining pieces to this kit is by far the cp-e™ Focus ST DownScream™ Downpipe. Made with 3.00” 304 stainless steel, this downpipe eliminates the stock catalytic converter to allow for smooth exhaust flow and transition. Not only is this downpipe designed to give a free flowing exhaust from your turbo, but it is also designed to attach to the Tial MVR External Wastegate. The wastegate actuates at high pressure and causes the system to divert the engine exhaust away from the turbo.
No turbo kit would be complete without the proper coolant and oil lines. cp-e™ has done it right once again by also supplying you with steel braided —AN lines for your coolant and oil routing that will fit right in with your new setup. These lines are complete with crimp-on swivel fittings so that you can ensure a leak-free and easy installation. On top of that, all the lines are covered with heatshielding along the whole line to prevent issues from heat. We’ve even gone as far as to make a custom CNC milled oil return fittings to provide the proper oil flow and perfect fitment.
What makes the cp-e™ Atmosphere™ stand higher than the rest is not only all the features built in, but the modularity of the kit. The kit will not only bolt-on with any cp-e™ products, but also allows you to upgrade your big turbo again in the future. Get a smaller GT28 now, and easily swap in the GTX35 later. Everything stays the same; all you need to do is get the new turbo. That need for speed of yours will always be satisfied!
If you are interested in the Atmosphere kit, there is limited availability, so please send me a PM, and we will get you taken care of!
Click below to check this out on our site!
cp-e Atmosphere Turbo Kit Focus ST - $4267.32
Banned
Can't wait to see some dyno numbers
Reactions: EdgeAutosport.com
1 - 16 of 16 Posts
