1 - 7 of 7 Posts
Pretty sure I have a boost leak, I'm gonna take apart the front bumper and change out the original worm clamps, I couldn't get the t-bolt clamps on originally when I installed my fmic last year.
I tied to use a 67-72mm which I thought was 2.5" (maybe they were more like 2.25") but it was too tight, so I gave up and re-used the stock clamps... my mistake!
What size t-bolt clamps should I use? 2.5" or 2.75"?
HPS (SSTC-70-78) 70mm - 78mm Stainless Steel T-Bolt Clamp for 2-1/2" Hose https://www.amazon.com/dp/B0058W7WK6/ref=cm_sw_r_cp_api_vYkvybHB6TGDX
HPS (SSTC-76-84) 76mm - 84mm Stainless Steel T-Bolt Clamp for 2-3/4" Hose https://www.amazon.com/dp/B0058W7X0A/ref=cm_sw_r_cp_api_UYkvybQD3H90C
That link is for the 2.50's
HPS Stainless Steel T-Bolt Clamp 70 millimeter-78 millimeter (2.76 inch-3.07 inch) for hose with 2-1/2 inch (63 millimeter) inside diameter. I was basing it off of the outer diameter after researching the ID requirement..
Works well.
1 - 7 of 7 Posts
