I got another shop to look at it today and they told me struts and bushings. The quoted $2,500 so that’s definitely a better price compared to 4k 🤣 I still might do a motor mount while I am at it. Thank you all for the help! It’s much appreciated 😊
@LaTina
Life is an interesting game . . . it's all in how it's played. When I saw your quote in my email list, I was thinking "struts and bushings of what?" . . . but from the, what is that a cell phone app report, it seems like, as was mentioned here before, "the shocks"???? The OEM shocks are a wear item, and from response here they are good for 16K miles??? Can't remember, but it isn't very impressive . . . so if the car has 80K on the OEM shocks then they are over due for replacement.
Still the question is, what is the history of this car?? Lots of washboard dirt road driving??? It has been rallied and beat hard?? Or, it's a daily driver on normal road surfaces? Possibly "sway bar links" could be worn . . . "bushings" of any OEM source probably could be "worn."
But, reason for posting, with both cars, trucks, and motorcycles I have thrown money at a problem, trying this idea out or that, and usually the
fix finally shows up, and it's simple, and relatively "inexpensive."
I know prices for everything are "up" . . . but still "$2500" to replace two front shocks" and sway bar end links??? Still seems "high" . . . ???? Others may post in with hard numbers.
But, like I said at the beginning, it's "how you play it," . . . if you are "shopping for a number" that is what is happening. If you make some decisions about your "project" . . . then you are calling the shots, mostly, and then sometimes while doing that "creative" process, the techs will say, "This is breaking, you should think about it." So, if you look in my sig line you can see "mountune clubsports" . . . I did that a while back, and that was "worthy" . . . it lowers the car around an inch, and it goes to Bilstein shocks . . . . I haven't looked at the price they are charging now, but pretty sure I got all 4 units, installed, for under $2500???
So, based on the service history of the car, never replaced the shocks?? OK, you probably do need shocks. But, to not have the tech shaking the "strut" or the sway bar end links in front of you to show you indeed, they are "weak" . . . start with the cheap and easy ideas and work up. The post with the idea about "lubing everything" would be a good start . . . . Be prudent. There are a few parts that do
want to be upgraded, FMIC, RMM, UMMs . . . and shocks.
