1 - 3 of 3 Posts
I was planning on getting an auto dimming mirror installed, so I disconnected the battery's negative terminal. Before I do this, the sunroof was left fully open, and when I connect the battery terminal, the sunroof switches won't work at all. I have checked fuse 80, and 85 are both in tack, and tested them with a multimeter.
Does the sunroof need to be reseted once a battery interruption happens?
I've tried the relearning procedure from the manual, and since the switch doesn't do anything, it can't be completed.
How did you fix the moonroof? Iv tied everything and I cant seem to get it to work. The moonroof button does nothing
1 - 3 of 3 Posts
