So, here’s all the stuff you need to know
Mods- front mount, intake, e30 tune
What happened- the other day I took a Datalog and my car was running great. Power was as good as ever. Then today, I started noticing my power was down. So I just took a Datalog 20 or so minutes ago. Threw them into virtual Dyno And I was right, on the weaker pull from today I was down 20-40 torque and 15-25 horsepower through out the entire pull. Consistently down everywhere.
The only external difference was the ambient temp. It was about 15 degrees warmer today. The stronger pull from the other day had a charge temp of 45 ish, while the weaker pull from today was a little above 60. But there's no way that should have caused a reduction of power of that magnitude. (I checked all the boost hoses and nothing felt loose, nothing looks off in the engine bay)
Comparing the logs the big thing I noticed was load. on the good pull, the load reading was normal around 2.6 or so at its peak, on the weak pull, it barely reached 2.2. I don't know what would cause that sort of sudden reduction in load. As far as I can see all the other parameters look okay? Boost is still there, air fuels okay, there were no ignition corrections, oar was at -1. airflow mass is perhaps down a bit. But that's not an actual reading it's calculated from other readings and the weather was also warmer.
the only other difference between the 2 pulls was I filled up with gas in between the 2 pulls. Mixture of e85 and 93 just like I always do. But that shouldn’t be of any significance.
