1 - 16 of 16 Posts
Hello,
I just bought a 2016 Focus ST, I love in California and since moving Isn’t an option for now does anyone know if it is bad to do a catless DP and resonator delete? Could this hurt the engine in any way? I plan on doing minor upgrades like IC and intake but I don’t want a loud exhaust.
2017 Kona Blue ST1
This is my exact setup. Depo catless with full factory exhaust. It does slightly increase the sound of the turbo but it's negligible exhaust DB change at best. I would be willing to experiment with an aftermarket resonator but only after I do the math for a helmholtz resonator in tandem.
Reactions: roundhouse
I don't believe it will harm anything, but the stock exhaust is restrictive, so it's not going to do much for you vs an aftermarket catback.
The stock exhaust isn’t that restrictive, you can get away with it on a BT build easily. The DP becomes an issue before the catback does.
A nice quiet setup is a DP on the stock exhaust.
I guess I meant "more restrictive" vs a 3" Catback.
I would leave the cat on and remove the resonator.That thing is a monster and has a smaller inside dia.than rest of exhaust.
My brain hurts trying to even think about accounting for that, due to the massively variable exhaust temperature. Something tells me that ballparking it and building an adjustable length one will be more effective.
Discussion Starter · #11 ·
Thank you all for your comments and input. I will follow up with you all after I decide what I am going to do.
I have an MRT axle back; it has a "J" tube helmholtz built in. I could measure it for you. Running just the factory resonator through the axle back there is no drone what so ever.
2017 Kona Blue ST1
I would be very interested in placement and length. I'm looking to build in a adjustable length set up.
Reactions: TurboGT
Placement is easy; it's an axle back set up, so the resonator sits where the muffler used to.
382586
But, I believe the important factor is the volume. Measuring from where the right side tip is welded to the pipe, around the outside to the end of the "J" tube is 43 inches and the pipe is 2.5 inside diameter.
Reactions: SSgtjrobertson
2017 Kona Blue ST1
Thank you!
1 - 16 of 16 Posts
