1 - 2 of 2 Posts
hey everyone, i just recently got my clutch replaced by the dealership less than 6 months ago, have put no more than 1k miles on it since, ive had the issue of a clutching getting stuck after being pressed, i took it to the dealer and they bled the brakes and it was fine for a while until today, although this time the abs and traction control lights turned on with it, anyone a had similar issue?
There's numerous accounts of clutch master cylinder and clutch line restrictor failures, but none with ABS/Trac codes. That may just be coincidence.
To test, you can remove the clutch line restrictor where the steel line meets the rubber line by the firewall. Its a large round black plastic piece that's plugged in-line there. Remove the restrictor and plug the rubber line directly into the steel line. If the issue continues, it's more than likely the master cylinder.
Its a good idea to replace the whle restrictor/clutch line with a braided stainless unit anyway, but doing this is for the sake of diagnosis.
1 - 2 of 2 Posts
